Direct mount Wilde/Keystone pups?
Discussion in 'Just Pickups' started by blackbelt308, Feb 11, 2013.
  1. blackbelt308
    blackbelt308 Tele-Holic
    Columbus, Ohio
    Anyone successfully mounted a Wilde or Keystone pickup directly on a Tele body (neck or bridge)? I ask because Bill uses threaded bushings for the mounting screws, and this would seem to complicate things a bit... Seems like you'd either need real skinny screws or to simply remove the bushings from the base plate (ugh!).
    Thanks,
    Rick
  2. unccivil
    unccivil Tele-Meister
    Charlotte, NC
    I've had this problem with keystone necks too...and I found out last year that I wasn't the only one.
    http://www.tdpri.com/forum/archive/index.php/t-327115.html
    I thought I was cross-threading them at first, but after an hour or so of trying to work them in, I figured it wasn't me. My keystones eventually went into a tele with pickguard mounts.
  3. jamieorc
    jamieorc Tele-Holic
    Virginia
    Can't you just use some smaller wood screws? Fill the original holes if you need to. Get some that have threads only part way up.
  4. Tele-phone man
    Tele-phone man Tele-Afflicted
    Asheville, NC
    The little threaded bushings he uses are removable. You can just push them out of the base of the pickup and then have a hole plenty big enough for a wood screw. Both of my Wilde equipped Teles have the neck pickups directly mounted in just this manner. Save the bushings for later if you change your mind.
