Did i make a mistake???
Discussion in 'Finely Finished' started by JoshNackerman, Jun 28, 2014.
  1. JoshNackerman
    JoshNackerman TDPRI Member
    Pennsylvania
    Hello TDPRI,
    After looking at a bunch of threads, im noticing quite a bit of guitar bodies that don't have the pickguard screw holes drilled before the finish process has been started... well... I have all holes drilled and am now ready to start the finishing process.
    did I make a mistake? or is it ok to start? should I fill the holes with something? paper towel? cork? idk. or will there not be enough build up to matter as far as clearance goes. IE: neck pocket, string ferrules, pickguard screw holes.
    ALSO.. What if I installed the string ferrules in the body before I started finishing,, and just have them be part of the guitar. they are inset only slightly, so it wouldn't impact the sanding process of finishing.
  2. stankepanck
    stankepanck Tele-Holic
    Greensburg PA
    Did you put the holes in the location of a pickguard you already have? If you i think it will be fine. I would wait until after the finish is applied to do the ferrules.
  3. mefgames
    mefgames Friend of Leo's Double Platinum Supporter
    North Bay, Ca
    You can put a bit of wax in the holes. It's easily removed later.
  4. JoshNackerman
    Pennsylvania
    Yes. I made the pickguard, then drilled the holes appropriately.
  5. Tom Pettingill
    Tom Pettingill Tele-Holic
    California
    The holes are not an issue for the finishing itself. They can pose an issue though during the wet sanding / polishing phase. In general, its a bad idea to let water / moisture into the holes as the underlying wood will swell. That is why some wait to drill them, or opt to plug them with a little wax or plumbers putty.
  6. flyingbanana
    flyingbanana Poster Extraordinaire
    Southern, California
    You can also avoid the pitfalls of getting water under the finish when wet sanding, by using naphtha instead. And this works even better than water...
    Just wear some latex/thin rubber gloves.
  7. Mbechmann
    Mbechmann Friend of Leo's Ad Free + Supporter
    Grindsted, Denmark
    How about a clear pickguard? That way, you still see wood, and you have the pickguard as well
  8. JoshNackerman
    Pennsylvania
    Are you saying use naphtha to wet sand?
  9. Buckocaster51
    Iowa USA
    Admin Post
    Yes, that is what the man said.
    It works fine.
    Use normal precautions.
  10. Jupiter
    Jupiter Telefied Ad Free Member
    Osaka, Japan
    I've used it instead of water; my only gripe is with how fast it evaporates. I went through a lot of it in a short time. I've also used mineral spirits; my only gripe with it is that it reeks. I used it out on the patio, which just made it bearable.
