I built a StewMac Ghost Drive Klone a couple weeks back. I installed a green LED instead of the clear that came with the kit. It sounded awesome, and had no issues. I wanted a different LED color, so I pulled the board out and put in a new LED (same LED as the green, just a different color). When I started playing it after installing the new LED I was getting a loud pop when engaging the pedal, the pedal was working intermittently, and anytime I moved it it would either make loud noises or stop working. I thought maybe a solder connection on the input jack was poor so I disconnected all the lead wires, sucked the solder from the jacks and power connection, and “started over” with new wires and clean jacks and power adapter. Now it’s worse. When I touch/jiggle the wires on the input jack or power supply I’m getting loud sounds/“thumping” noise.
Did I fry the PCB? Did I fry the jack/power supply? I’m not sure what to do next. I love the pedal (it sounds better than my KTR!), and want to get it working so I can have it on my board, but the popping/thumping sounds it makes when engaged make it unusable. Any help is appreciated!
