Did I buy the wrong Fret slotting saw?
Discussion in 'The DIY Tool Shed' started by Grim Reefer, Feb 22, 2020.
  1. Grim Reefer
    Grim Reefer TDPRI Member
    Sweden
    I ordered a Hosco Dozuki fret saw with a 0.6mm Kerf and Black Smith brand (DHP 272C) fretwire that I now noticed is for 0.58mm fret slots. It´s just a +0.2mm difference, should I have gotten the saw with 0.53mm kerf saw instead? Items have yet to arrive...
    It says the Tang is 1.8, but it seems to be referring to the height not the width, can´t seem to find any info of tang+stud width either.
    Fret board is made of rosewood
  2. RodeoTex
    Nueces Strip
    I think you're ok.
  3. Treadplatedual
    Treadplatedual Tele-Holic
    Indianapolis, IN
    You're fine, make sure you run a file along the edges of each slot to gently break the "corner" the saw will leave, and if the frets wiggle (they won't) you can wick some thin CA glue into each.
  4. telepraise
    telepraise Tele-Holic
    Tampa Bay
    0.53mm = 0.021 inches which is what fret slots are usually cut at. It's the barbs on the tang that actually hold the fret in. An extra 0.003" probably won't make a significant difference.
  5. Grim Reefer
    Sweden
    Thanks guys!
