Dewalt DW735 13" Planer
Discussion in 'The DIY Tool Shed' started by jkingma, Aug 27, 2019.
  1. LeftFinger
    LeftFinger Friend of Leo's
    Saskatchewan
    This is what my 13" King commercial looks like[​IMG]
  2. RogerC
    RogerC Poster Extraordinaire
    Oklamerica
    Correct me if I'm wrong, but they have that labeled as a helical cutter head, but the cutters appear to be linear.
  3. LeftFinger
    Saskatchewan
    Can't correct you
    When your right your right:D
    I was a little miffed when mine came because of that , but then I tried it out.
  4. guitarbuilder
    guitarbuilder Telefied Silver Supporter
    Aren't the carbide cutters staggered in a helical( spiral) pattern around the shaft? That's what it looks like.
    LeftFinger likes this.
  5. RogerC
    Oklamerica
    To me it looks like they’re not.
  6. Jim_in_PA
    Jim_in_PA Tele-Meister Ad Free Member
    SE PA near New Hope PA
    Yes, it's my understanding that there is, um...a relationship...between the two companies.
  7. guitarbuilder
    check out 1:13
    LeftFinger and RogerC like this.
  8. RogerC
    Oklamerica
    Yep, you're right, Marty. Now I see that I was just looking at it wrong. I was just focused on the single row of cutters and not looking at their position relative to the next row.
  9. LeftFinger
    Saskatchewan
    They create the effect of a "Helical cutter head " That's Add Speak . Also known as dancing close to the edge of truth. Whatever it is it cuts quite smooth
  10. Davecam48
    Queensland Australia
    With the staggered cutter layout it should cut with very little stress on the machine as only one or two cutters would be actually starting to make a cut at any point in time. Looks to be a good set-up!
    DC
  11. Davecam48
    As a matter of fact I have been looking at thicknessers myself. I wanted to get one for my son's birthday. I have one, but he borrows it from time to time to use in his business, so I thought if I got him one I could recover mine.
    There is one with the replacable square cutters which I would like but the price is way higher than a "normal" machine but I don't use mine very much at all, so finding it hard to justify the cost.
    Most of the time when I "thickness" wood I cut it close to size on the band-saw then whack it through the drum sander until its spot on the required size.
    The chip vacuum feature would be worth having though, mine just spits it all out on the floor and everywhere else.
    On the other side of the argument ....................when I kark it, he'll have two!!!
    Decisions decisions!
    DC :confused:
    jkingma and getbent like this.
  12. DrASATele
    North of Boston
    I have the Dewalt and love it. I've had it for 3 1/2 years haven't replaced the blades yet. However I am just starting to see some lines on pieces in the last few weeks so I'll probably dip into my stash of blades soon. Great tool.
  13. Vizcaster
    Glen Head, NY
    An accessory chute for a dust collector is vital! Not only does the machine make a mess, but all the chips can get back underneath where they wreak havoc on the feed rollers. Either it will cause the rollers to lose traction and feed the board inconsistently, or they'll mash into the surface causing divots, unless you run the dust collector with the accessory chute.
    DrASATele likes this.
  14. DrASATele
    North of Boston
    Very good point, I run a cyclone and my rigid shop vac when using it. If I don't it ends up looking like winter in the shop and then there's a ton of cleaning the shop and the machine afterwards. I use my chips and shavings from the planer to get my fires started in the winter.
