Dewalt DW735 13" Planer
Discussion in 'The DIY Tool Shed' started by jkingma, Aug 27, 2019.
  1. jkingma
    44°55'09.9"N 79°25'39.1"W
    Admin Post
    Does anyone have one of these? I'm looking for a small planer for the cottage shop and see a used one of these for sale locally at a decent price. I have no experience with benchtop planers. I've only ever used 16" and larger. But this would be perfect for me if it's any good.
  2. Boubou
    Boubou Doctor of Teleocity Gold Supporter
    Montreal, Quebec
    Have one, love it even though I haven’t used it in a while. One of the best if not the best in its class for not causing snipe
    6stringcowboy, KG7IL and jkingma like this.
  3. RogerC
    RogerC Poster Extraordinaire
    Oklamerica
    I don't currently have one, but I've been on the look-out. As Boubou said, they're probably best-in-class for portable planers. Much better design than any of the other lunchbox style.
    jkingma likes this.
  4. LeftFinger
    LeftFinger Friend of Leo's
    Saskatchewan
    I have the 13" King Commercial with the Segmented blades I love the performance.
    The 13" Dewalt was my second choice since its cutters can be upgraded
  5. guitarbuilder
    guitarbuilder Telefied Silver Supporter
    I have it. The rubber rollers don't like to be cold and you'll end up pushing the wood if they are. Knives don't stay sharp that long but are easily reversible. The replacement knives are pricy though. You still get a bit of snipe but not as horrendous as some lunchbox planers. It does have a slower feed which is nice and the built in blower helps get rid of chips outside if you have a place to blow them. I probably wouldn't buy it again, but would aim for a heavier duty stationary one. I bought a Delta 13 for the basement last winter because of the cold issue. The Delta weighs less for an old man with a messed up back lifting by himself.
  6. jkingma
    Admin Post
    I took a serious look at the King just for that reason. But I'm on the lookout for something used and the Dewalt one came along.
    LeftFinger likes this.
  7. jkingma
    Admin Post
    I've heard this complaint from a few people.
  8. cgharrison
    cgharrison TDPRI Member
    Los Angeles
    Great planer
  9. cleanheadsteve
    cleanheadsteve Tele-Meister
    Arkansas
    i had one i bought for $50 from a pawn shop. put a new (used) motor in it and ran like a champ.
    i also had one of the 12.5" foley belsaw planers. heavy duty and really easy to work on. ran great also but i sold it because it was only 12.5" and i wanted 13". i also sold the dewalt 735 after i got it running because i didn't really need it. wish i had it back now. but it would have to be a great deal on a used one for me to buy another. they are pricey.
    Sent from my SM-S767VL using Tapatalk
  10. screefer
    screefer Tele-Meister
    kildonan
    I looked at one but ended up buying the Makita 2012 as it is 30 lbs. lighter and way quieter. I schlep mine quite a bit and I ain't getting any younger!
  11. Obsessed
    Montana
    I have one and it is awesome. I have planed an entire house of ceiling t&g, door jam, and window trim from rough cut fir, cedar and pine off our property. Also 2"x12"x16' long pine flooring from rough cut. After all of that, I planed some fine walnut cutting boards as gifts.
    A huge benefit is the chip blower. I built my own collector with scraps dumping into my four wheeler box trailer to haul away.
    I have a bad back, so it takes another person to help me move it everytime I need it. The blades cannot be resharpened, which to me is the biggest negative, but the replacement blades last a long time and are reasonable in cost.
    getbent likes this.
  12. Stefanovich
    Stefanovich Tele-Holic
    Kingston, Ontario
    I do not own one but have used a friend's on multiple occasions. The performance is nowhere near what a good quality large planer can give you. Having said that, it did the jobs I needed it to do. There is some snipe. By finishing with very shallow cuts, I was able to reduce the snipe considerably, but it never disappeared. I have not tried other benchtop planers and so cannot compare. If one of these came up cheap locally, I would likely buy it, but it is not a tool I MUST have.
  13. jkingma
    Admin Post
    I have a 16" industrial planer at home, but I'm looking to set up a small shop at my cottage. I don't really need it... but it's available, and priced right.
  14. Obsessed
    Montana
    My neighbor has an industrial planer and it does a better job with snipe and much faster. I was able to plane two rough cut softwood 1x4s at the same time, but three was too much. It does have two speeds that dramatically reduce snipe, but much slower. If you do get it, the optional extended tray is very important to reduce snipe.
  15. CapnCrunch
    CapnCrunch Friend of Leo's
    Washington, USA
    I've had a similar experience with mine. If it is cold the rollers don't like to grab. The cheaper Dewalt 12" is a better planer in my experience.
  16. guitarbuilder
  17. LeftFinger
    Saskatchewan
    and for another $500 or so you can upgrade to
    [​IMG] :p
    guitarbuilder likes this.
  18. Obsessed
    Montana
    Another nice attribute is the low profile for passing boards over for another pass. Industrial planers are designed this way, but lunchbox planers are a PITA for this. Of course, I'm planing rough cut wood down to the size I need, so sometimes that requires a bunch of passes.
  19. LeftFinger
    Saskatchewan
    Wait until you are making 1/4 " book matched door panels out of 1" rough :)
  20. jkingma
    Admin Post
    I spent too much time thinking about it and someone else bought it. So I'm on the lookout for another to come along.
