Demiurge Instruments Broadcast issue
Discussion in 'The Stomp Box' started by Seasicksailor, Jul 21, 2019.
  1. Seasicksailor
    Seasicksailor Friend of Leo's
    Bristol UK
    A few months back, I got the Demiurge Instruments version of Broadcast. It's an absolutely amazing pedal resulting in some excellent sounds. I absolutely love it.
    My initial plan was to use channel 1 as an always on situation (with hardly any gain) and switch to channel 2 for a solo boost.
    However, there is no separate volume control for channel 2 (only gain), and the jump in volume from 1 to 2 is extreme. The only way I have dealt with it so far, is to bring down the volume on the guitar. But when I do that, the thing cleans up substantially when the sound of channel 2 at full guitar volume is BEYOND THIS WORLD.
    Any suggestions how to deal with this? I looked inside the pedal and there are no dip switches (I think the original Broadcast has some... but not sure what they do).
    Any suggestions? Is there a mod that can be done perhaps?
    Many thanks in advance oh wise ones! :)
  2. Gunerius
    Gunerius Tele-Holic
    Norway
    Seasicksailor likes this.
  3. Seasicksailor
    Bristol UK
    Thanks for that, but sadly no trimmers in the clone.
    Yep, I guess one solution is to get an actual Broadcast. :(
  4. Seasicksailor
    Bristol UK
    Bumpety bump! :)
  5. Seasicksailor
    Bristol UK
    Ok... so this is my list of options as far as I can tell:
    - Replace pedal with original (expensive and waiting)
    - Place a compressor (I don't have) right after it
    - Somehow mod the pedal (I'm exploring this option - I've emailed Demiurge for suggestions)
    - Only use the one side (that's what I'm doing at the moment)
    Any other ideas?
  6. Paul in Colorado
    R.I.P. 2019
    Figure out where the trim pots are in the Broadcast and have them put in your clone. Have a tech do it if you don't know which end of the soldering iron to hold. :D
  7. Seasicksailor
    Bristol UK
    Good idea! Thanks!
    Paul in Colorado likes this.
  8. artdecade
    artdecade Poster Extraordinaire
    Boggo Road
    Send it over to Hudson Electronics and see if they will mod it.
  9. Norris Vulcan
    Norris Vulcan Tele-Afflicted
    Somerset, UK
    " The low-gain trimmer adjusts the overall gain of the pedal and the high-gain trimmer adjusts how much gain is boosted (on top of the low-gain) once the high-gain mode is engaged."
    This suggests the trimmers may not have the effect you're after, you want more of a 'master volume' on the loud channel.
    Probably still worth a try, though, if it's easy enough to do ?
    http://freestompboxes.org/viewtopic.php?f=7&t=27085&hilit=hudson+broadcast
  10. Seasicksailor
    Bristol UK
    Great Idea! Just an additional volume knob!
