Thanks ST, that's an option I'm considering, thanks for the suggestion. My plan is to get things back to stock, except the new AC cord and wiring, and make sure everything's shipshape first, then go from there with any mods.IMHO, Convert the ground switch to a "switchable negative feedback loop", that's what I did with my DR,...one way on the switch is stock and the other way is more "ballsey" and breaks up easier
Hi Bluzzi, yep, the eyelet board, along with several other items, is in rough shape. One of the mounting screws on the board is missing. I'll check the board for conductance, and it looks like I ought to go wore-by-wire and check everything.The bypass switch looks like it is just being used for soldering the wires before they go to the fuse and switch. So it is not being used for any switching. For my taste I would just rather use one length of wire directly to the fuse and the XFR. Use shrink wrap to insulate any soldered bare leads. Then there is no ambiguity for anyone looking at the amp in the future.
I would replace all the bypolar caps and while you are at it why not all the caps. Measure the resistors to make sure they are to spec and within tolerance. Also get hold of a schematic and wiring for AB763 DR amp. I bought a 1969 SR that was modified enough that it was no longer a SR. I am bringing it back to original spec.. New XFR, all new caps and also replacing all the resistors. I went over every single wire and component to make absolutely sure what was modified. If you find any modes on yours and you want to keep them you should make notes and keep them with the amp cabinet for the future.
The eyelet board on mine looks way cleaner than yours and that could be a source of problems (rare but its worth checking). If you have a high quality VOM measure to see if there is any resistance on the board itself. It should be infinite (unless NASA lent you their gear). You can get micro leaks that no amount of component replacement will fix because its on the board itself. If your VOM is not sensitive enough you will have to turn the amp and measure any millivolts leaks.
Yeah, Milspec, I love the EVMs in a DR. The first EVM I put into this amp was one of the older ones, without the fins. I got my hands on a TR back then, that was missing a speaker, and thought it was a good idea to stuff 2 EVMs into it. I found this finned one and found out just how heavy an amp could be! I eventually sold that amp, I'm not sure where the other EVM went. Hey it was more than 40 years ago.I can't help with any of the wiring stuff, but do what you have to in order to keep that speaker...one of the absolute best for the DR.
