Hi guys. Feeling cocky after refurbishing an old Twin Reverb, and a Princeton Reverb kit build, I figured it was about time to dive into my old DR, which has been a trusty workhorse for 40 years. I replaced the doghouse caps 8-9 years ago with black F+Ts. The reverb stopped working about 6 years ago, then the vibrato stopped working. I fixed them by buying a Mr Black reverb/trem pedal, which crapped out a couple months ago.
I've spent a few hours reading and looking stuff up, but several items have me a bit stumped. I so much appreciate the generosity of attention and advice I have gotten from the amp gurus on this forum, thanks for checking in.
My main issue, is finding the best wiring diagram to replace the 2-prong power cord, complete with the original death cap. I searched TDPRI, and Rob Robinette's site, but couldn't locate the info. There's this diagram, from guitarfella.com, should I bother with the ground switch, or just bypass it?
Next, is trying to figure out what year and model I am dealing with. The paper tube tag indicates an AB763 circuit, which seems correct. The chassis serial number, A31742, indicates 1969. I bought it in '79 or '80. Are the chassis S/N a reliable way to date the amp?
As you can see in the pictures, things are a bit hairy in there. The bright pink cap, which I think is the trem tube cathode bypass cap, was visibly corroded, and one of the leads was completely disconnected from the body of the cap, which might explain the vibrato problem. I replaced that with a new F&T.
There's a couple weirdo caps. The .001uF trem coupling cap looks like an antique molded red bakelite square. I'm assuming it's OK. Next to that is a black Sprague 0.1uF, the AC shunt cap for the V6 phase inverter, which I'm also assuming is OK.
Aside from replacing the power cord and switch wiring, and the bad cap, do you have any suggestions, or is there something I should be looking for while I'm at it? Thanks again. Some pictures:
