Paul G.
I'm old and tired. My gigging amp is an Allen Accomplice Jr. While it it pretty light at 38 lbs., but the cab is pretty bulky. I was thinking of putting a single-channel AB763 into a PR chassis and cab running Deluxe Reverb transformers. (I've owned PRs, I need a bit more power and a better phase inverter). Anybody done this? Any stumbling blocks? Was going to stick to the cap can to save space, unless having the preamp common to power amp ground causes a problem.
I'd need to punch one more 9-pin hole, and open up the PT hole, otherwise, it should be good, right?
