deluxe reverb booster
Discussion in 'The Stomp Box' started by gianluigi, Apr 7, 2021.
  1. charlie chitlin
    Kimberton
    This pedal with a Tube Screamer is a mighty MIGHTY sound!
    I put mine after the TS and it changes everything.
    BB and Oxidao like this.
  2. nedorama
    nedorama Tele-Meister
    Forgot to mention, but yes, sounds good on 9V, sounds even better with 18v. But if you don't have the Xotic voltage doubler, don't worry - still sounds great.
    PBO Blues likes this.
  3. PBO Blues
    PBO Blues Tele-Holic
    Chatham County, NC
    Indeed. Great either way. Luckily, my board's power supply gives me 18v options so I don't have to mess with Xotic's doubler.
  4. telepraise
    telepraise Tele-Afflicted
    Tampa Bay
    +2 on Xotic EP Booster
  5. 2after909
    2after909 Tele-Holic
    brooklyn, ny
    RC or AC booster are both great. Spark, LPB-1, and Micro Amp would all do the trick. Z Vex Super Hard On is awesome if you like a sparkle added. I love that pedal. It's a very simple circuit, too, and the laughably cheap Mosky SHO pedal is a dead-on copy of it. I've got two of those.
    Oxidao likes this.
  6. Rich_S
    Rich_S Friend of Leo's Gold Supporter
    Potsdam, NY
    I found the LPB-1 fattened my tone, which (like the OP) was not what a wanted. I built an Alembic Stratoblaster circuit into a pedal and love it.
  7. monkeybanana
    monkeybanana Tele-Holic
    mmhmm
    I have a Princeton NO Reverb and use an Orange Squeezer clone for boost. The compression is subtle so no bass boost.
  8. Twang Deluxe
    Twang Deluxe Tele-Holic
    Kehl
    For boosting my DRRI I used GE7, a Bad Monkey or a MojoMojo.
    I always liked the Bad Monkey best
  9. schmee
    schmee Doctor of Teleocity
    The EP Booster sounds good, but to me it's not a simple clean boost. So that is something to think about.
    It adds a little compression which you may or may not want. It's is reportedly based on the tone from an old EchoPlex unit.
  10. northernguitar
    northernguitar Friend of Leo's
    North of Toronto
    Treble booster is where it’s at.
  11. nedorama
    It is definitely modeled after the preamp circuit from a EP-3 Echoplex, so by design it isn't clean. Also has a DIP switch inside to either be flat, have a mid boost, or add at +3db boost when on. I had a Keeley Katana boost before which is ultra clean, and swapped it out for this instead - I like the fact it's not clean...
    schmee likes this.
