I'd go for a small modeler and use it soley for effects. Hotone Ampero Mini is small but will allow up to 9 effects. I use the Ampero II stomp for my delays, the sounds are excellent. The A2S is surprising in how good it sounds, on par with the Helix to my ears.
The Mojo Hand Park Theatre has an echo time and a feedback control, plus dry/mix, and is a very cool pedal.
Might not do everything a straight up delay or a reverb does, but it bridges the gap between the Sonic concepts of reverb and delay in a very usable way. And reverb is a delay, technically, so it was nice to have MHFX explore the concepts. It isn’t a one-trick pedal, either. You can get straight slap back or beautiful washy reverb, or go out way past Pluto and channel your inner Jonny Greenwood. I have found a lot spots within the settings that all do
Something a little different.
I started using my Ibanez AD9 for dirty texture (self oscillation)… sort of like an ambient pad, which was one of the ways I used to set the Line 6 DL4. Now that I played the Park Theatre, and bought one, I’ve very nearly retired the Ibanez and Line 6. It’s so easy with three knobs.
I've used some different ones that are good but currently like this one. It is more subtly used here but not a one trick pedal
as can do various classic to modern variations.
Keeley Memphis Sun Lo Fi Delay Reverb Effects Pedal
This is the hard to find FD-900 Delay from MUZA. This unit has been getting great player reviews and comments and now another chance for you to pick up one of these great floor effects which will add huge space and delay modulations to your sound. This is the latest version of great sounding FD-90 Delay/Reverb that had gotten a very good buzz and word of mouth and then became very hard to attain.... until now. I have a few of these units (brand new) that I am offering here! The new FD900 features all the acclaimed tones and options as the original FD-90, but now features dual line outs, where on the FD90, a "Y" adapter was required to obtain line out to seperate amps. Improved clarity and a new appearance is also present. Introduction: FD900: M Ambience is a digital delay and reverb effects pedal, contains 10 excellent delay effects and 11 excellent reverb effects. It also includes the storage function, allows you to store and recall up to 4 patch memories. DELAY MODE: 1.0-1000ms STEREO DELAY 2. 1000-3000ms STEREO DELAY 3. 100-3000ms PAN MOD. DELAY 4. 10-500ms MONO DELAY 5. 500-1000ms MONO DELAY 6. 1000-6000ms MONO DELAY 7. 10-1000ms ANALOG DELAY 8. 10-1000ms MODULATED DELAY 9. 100-3000ms REVERSE DELAY 10. 200-12000ms SOUND ON SOUND DELAY REVERB MODE: 1. ROOM I 2. ROOM II 3. 3 HALL I 4. HALL II 5. HALL III 6. CHURCH 7. SPRING 8. PLATE 9. REVERSE 10. GATE 11. MODULATE Delay Types: 10 Reverb Types: 11 Patch Memory: 4 Guitar Input: A pair of 1/4" monaural phone jacks Input impedance: 1 Mohms Line Output: A pair of 1/4" monaural phone jacks. Output impedance: 100 ohms Power Requirements: AC adaptor DC9V/300mA/center minus type or 6LR61 9V battery Dimensions: 2 1/2 " (W) x 5" (H) x 1 3/4 " (D) Weight : 13 oz. Great Delay from Muza Sound
I have an RV-6 that can certainly add a delay. I use it on my board frequently for reverb. If you told me I could only have one though, it would be the Dispatch Master. It can do just a digital delay, just a glorious reverb, or a stellar combination of both.
Oh, and I have an EQD Avalanche, which has a little more tweakability, but the reverb is not the same as the DM, and the DM is just something special. Get one in on of the nifty, limited-edition paintjobs.
