Delay or Reverb or both for live gig ? What do you prefer ?
Discussion in 'The Stomp Box' started by Thin white duke, Aug 7, 2019.
  1. Thin white duke
    Thin white duke Tele-Afflicted
    italy
    Hi, i'd like to know what do you think or prefer about using delay and reverb in a live situations.
    What do you usually use ?
    Do you think reverb it's not so indispensable because is already in the room and it can muddy the tone ?
    Is a slap back delay a good alternative of a reverb ?
    Do you use them both at the same time ?
    I've always been an always on reverb pedal fan but sometimes i feel that a delay doesn't muddy the tone as much as the reverb.
    I'm talking about using one clean amp with all the pedals in input, no send-return, no amp's drive and most of all no wet-dry rig.
    Thanks a lot.
  2. ScottJPatrick
    ScottJPatrick Friend of Leo's
    Stirling, Scotland.
    Always have the reverb on about 3 or 4 depending on the room, no problem adding a digital delay when I need it, using a TC Flashback.
    Marc Morfei and 41144 like this.
  3. Thin white duke
    italy
    Thanks, that's what i do as well but i've read that some people use a slap back delay instead so it made curious.:):):)
    jimash likes this.
  4. Spats Davenport
    Spats Davenport TDPRI Member
    Ireland
    I see reverb as an attempt to put back something that’s s lost, particularly with a solid body, while delay is more like an effect, an attempt to change the guitar sound.
    Playing at home, I like reverb, especially if sitting outside with my 5F1.
    Live, I’ll use delay if I want a 50s sound, otherwise neither. I find that in a band, you don’t notice the reverb until a certain point, when you really do notice.
  5. Thin white duke
    italy
    Thanks, i'll try with a 50's slap back, i never did......
  6. JayDee
    JayDee Tele-Meister
    Missouri
    I use reverb all of the time. I keep a delay pedal for occasional use when I think the song calls for that sound. I used to keep a separate delay pedal on my board to keep on all of the time for slap back, but I don't care for that sound anymore.
    Marc Morfei and Thin white duke like this.
  7. artdecade
    artdecade Poster Extraordinaire
    Twangsylvania 6-5000
    Noisy gigs? Delay.
    Quiet, restaurant style gigs? I might use some reverb.
    igor5 and (deleted member) like this.
  8. joebloggs13
    joebloggs13 Tele-Holic
    The Woodshed
    Delay would be the way To go I think. If it were me....I would be taking my El Capistan. It can be so many things.....:)
  9. Thin white duke
    italy
    This is an interesting answer. :):):)
    Thanks.
    artdecade likes this.
  10. Thin white duke
    italy
    Thanks a lot, very good pedal that one. :):):)
  11. Thin white duke
    italy
    Thanks a lot.
  12. charlie chitlin
    Spring City, Pa
    I've been using a DanEcho with the repeats off (1 repeat) and the delay so short you can't hear the "hit" of the repeat...it just fattens things.
    Then I like a little spring reverb along with it.
    JimInMO, mad dog and Thin white duke like this.
  13. King Creole
    King Creole Friend of Leo's
    Colorado
    I like delay better than reverb. I have a dual analog delay pedal that I set one side to a pretty short 3 repeats--it gives a little bounce to the notes, kind of like a little spring reverb, but clearer. The other side is set a little longer with more repeats (4 or 5?) but the mix is lower so it doesn't overwhelm the dry signal. It gives a smeary fatness and the illusion of sustain. Great for slide and atmosphere.
    Some gigs, like if I'm playing just old school soul music, I'll use only a little spring reverb and no delay.
  14. d-rock
    d-rock Tele-Meister
    Smithville
    I've been off delay for a while now and haven't looked back. I just find that it's not that important to my sound and gets lost with the full band. Reverb is always on so it doesn't feel so dry.
    Thin white duke likes this.
  15. schmee
    When I use reverb in the band mix it just seems to muddy things up. I seldom use it. Delay seems a little more distinct and controllable. not a big user of either though. Some delay on certain leads is nice...
  16. dlew919
    dlew919 Poster Extraordinaire
    Sydney
    My amp has a reverb so that goes on, and then delay. Usually slap back.
  17. Henry Mars
    Henry Mars Tele-Afflicted
    Bucks Co. PA
    I use delay in small rooms ... It helps fill the room without getting too loud. If used sparingly it can really help.
    I went out to hear some friends of mine play a while back ... between the delay and the reverb you had a jumbled up mess. I prefer delay when the entire band is using a single effect thru the board. Otherwise everything is a jumble
  18. Henry Mars
    Bucks Co. PA
  19. tfarny
    tfarny Friend of Leo's
    Hudson Valley, NY
    I have no use for reverb in a live setting - that's what the room is for. I hate it, in fact it drives me crazy if it's used as an always-on and it's not a part of the sound or style intended. I used slapback delay as an effect, not on every song. Mostly I'm happy to go straight in.
    nixpix and hemingway like this.
  20. brookdalebill
    Austin, Tx
    I gotta have a little of both.
    Just a little.
