DDRI Replacement
Discussion in 'Amp Central Station' started by HunterTheHunter, Nov 13, 2018.
  1. HunterTheHunter
    HunterTheHunter TDPRI Member
    Dallas
    Starting to feel less than satisfied with my Fender DDRI. It's super bass-y, doesn't have the clean headroom I need, and while I don't mind the amp's breakup for rhythm parts, it kind of fights me on lead lines. Doesn't really cut through like a Vox or Marshall would. On the other hand, I really love the Fender clean tone as the foundation of my sound. It's the sound I hear in my head, it just sounds like me.
    With that being said, I've considered other amps that might still have that Fender sound, have more headroom, less bassy, but breakup in more of a Marshall/Vox-y kinda way. The three amps in question are: Fender Prosonic, Fender Bassman 4x10, and Traynor YVC40wr. I've read about all of these amps having the qualities I'm looking for, but I'm worried the Prosonic will be too dirty (not enough headroom), the Bassman too dark, and the YCV too bass-y because of the single 1x12 speaker (like my DDRI).
    Any insight would be appreciated!
  2. schmee
    The Pro Sonic's always seem to sound dirty to me in a band mix, How can the DR be too bassy? Does yours have the Jensen C12K in it? Those have huge bottom end. Sounds like you need an OD that is middy and cuts through with it maybe.
    Not sure I've ever heard someone complain a DR is "too bassy" usually you hear "too bright". :>)
    Tell us more. What you play? How loud? Has the amp been properly biased?
  3. bftfender
    bftfender Friend of Leo's
    York PA
    why not a Marshall...
    Jakedog and Milspec like this.
  4. noah330
    noah330 Friend of Leo's
    Maryland
    1- What is a DDRI?
    2- How do you have it set?
  5. nojazzhere
    Foat Wuth, Texas
    I think a DDRI is the "too bassy" version of a DRRI.....
    BobbyZ, Fred Rogers and Whiskerz like this.
  6. Mutato
    Mutato Tele-Meister
    Rhode Island
    Look at Marshall Origin 50?
    bftfender likes this.
  7. noah330
    Maryland
    DRRI? Sell it and get something else.
  8. tonejam
    tonejam Tele-Meister
    brisbane
    If a Prosonic sounds dirty, it's because it was dialled that way.
    in 30W (voxy) mode, Prosonic will sound clean up to about volume 3. However, its DAMN loud at that point.
    In 60 watt mode, there's a LOT more clean headroom than a Deluxe Reverb.
    Prosonics kinda get condemned by their own versatility.
  9. stratoman1
    stratoman1 Friend of Leo's
    Virginia Beach, Va
    Would a speaker change help?
    ponce likes this.
  10. DougM
    DougM Friend of Leo's
    Honolulu, HI
    Is your DRRI the BF ('65) or SF ('68) one? Because a lot of people I know really prefer the SF one, and the Bassman tone stack on the first channel, while still having the BF sound on the Vibrato channel.
  11. Fred Rogers
    Fred Rogers Tele-Afflicted
    Long Island
    This
  12. theprofessor
    theprofessor Friend of Leo's
    Chattanooga, TN
    If your Deluxe Reverb reissue has the Jensen C12K in it, then that is your problem. As @schmee said, it has a huge bass response. There are lots of good speakers for a Deluxe Reverb, depending on what flavor you want. I highly recommend the Eminence JS-1250 or an Eminence GB128. Those will solve your problems of it being too bassy, and with either speaker, it'll still retain the basic tonality of a Deluxe Reverb.
    brbadg likes this.
  13. brbadg
    brbadg Tele-Afflicted
    Timonium,Maryland
  14. Mudman32
    Mudman32 Tele-Meister
    Upstate NY
    Try a new speaker. Turn the bass down. Try new power tubes (or at least check the bias). Tons of things to try first.
    Then buy a super reverb and smile. No replacement for displacement.
  15. zombiwoof
    zombiwoof Tele-Afflicted
    Tujunga California
    Any of those issues can be addressed by speaker and/or tube changes. No reason to get rid of the amp, unless you just don't want the classic Fender sound.
    Al
  16. Singin' Dave
    Singin' Dave Friend of Leo's
    Chicago
    DRRI's are not bass heavy amps typically, but yes those Jensen 12K's are bad speakers.
    I'd start with a new speaker. If that doesn't cure ya, then I'd sell it and buy thee a SF Vibrolux Reverb.
  17. Silverface
    Lawndale CA
    I'm also going to assume this means "DRRI". Are we right?
    A speaker change should take care of things unless it's an awfully loud band - honestly, unless [it's a Hardcore or metal band a DRRI usually has plenty of headroom for most club work. If the band is too loud for it even after a speaker change IMO it's time for a meeting about level and dynamics control.
    But a Prosonic *is* a viable alternative. The others on your list HAVE to be a bit loud to reach full frequency response. Wally and I have both spent a lot of time tweaking the Prosonic and tube changes can do wonders. One issue is that the 2nd "gain" control really isn't a gain control - it's a mids control; also, the tube stages are not "linear" - half of each tube is used in the preamp that's running all the time; Th other two halves of each are used in different ways - but it's not a 2-channel amp, it's a one-channel amp with a gain "bump" system. Trying 12AU7 and/or 12DW7 (1/2 12AX7; 1/2 12AU7) can really tame the "dirt" factor. I have one that basically sounds like a "doubled" Deluxe Reverb, but with aa tighter than "normal" speaker.
    If you have a good amp tech to work with I'd consider a Prosonic - you can pick them up cheap and there's quite a bit you can do with them. They're also build very well - they have a PCB, but with full-size components, and all the to/from board, tube socket and control wiring is hand-done. Makes them easy to work on.
    BobbyZ, LuthRavin, Modman68 and 2 others like this.
  18. RoscoeElegante
    RoscoeElegante Friend of Leo's
    TooFarFromCanada
    Try a different speaker or two before you plunge into amp changing. Can make a huge difference. The Eminence Legend 1258, for example, is nicely tight ad and cutting without being boomy. (And actually a bit stiff and spikey until it breaks in.)
  19. jackal
    jackal Friend of Leo's Gold Supporter
    mojave desert
    Some great speaker options are Eminence: Red White and Blues, Red Fang, and my favorite---Lil' Texas. As you can tell I'm a big fan of Eminence speakers.
    nojazzhere likes this.
  20. PastorJay
    PastorJay Tele-Afflicted
    California
    Deluxe Reverb Reissue?
    If you love the 60's era "Fender sound," but the amp isn't cutting it for you because you need more headroom:
    1. Try turning down the bass and up the treble;
    2. Try a speaker change (see several posts above)
    3. If you need a new amp, because you need more watts to get the clean sound you want:
    a. Try a Pro-sonic. People who love these truly do love these. And they're very versatile; One of the best amps I've heard but never owned (see comments above).
    b. The clean channels on the Blues Deluxe and Blues Deville are supposedly based on the Deluxe Reverb, but have more power. Try one of those?
    c. Egnater Tweaker 40 is very versatile, but sounds best to my ears in either Fender Deluxe or Blues Deluxe (Vintage) Mode. And has 40 watts, so almost double the power. add an additional external speaker, and you've got much more volume.
    d. Fender Twin or Super. Clean Fender tone. Much more volume. Of course you'll have to carry the darn thing.
    e. Put the right OD pedal in front of any of those, if you're into that sort of thing, and you'll get dirt for miles.
    Good luck.
