DC voltage booster
Discussion in 'The Stomp Box' started by czech-one-2, May 7, 2015.
  1. czech-one-2
    czech-one-2 Friend of Leo's
    East of you
    I just thought I would share something that has been a cool discovery for me.
    If you have an effect on your board that requires its own adapter due to its higher voltage requirements [in my case a 24v Mu-Tron III +] then this little voltage booster is the solution.All you do is add in and out DC jacks and you can dial in any voltage you need. I put mine in a 1590A enclosure and mounted it below my pedalboard. I'm not sure why anyone using an adapter wouldnt give this a try. Its adding no additional noise to my rig and my Mu Tron sounds better at 24v. Any body else use one of these?
    http://www.ebay.co.uk/itm/291342854195?_trksid=p2055119.m1438.l2648&ssPageName=STRK:MEBIDX:IT
      File size:
      15.9 KB
      114
  2. RyanJH
    RyanJH Tele-Meister
    I use something similar...a tiny 1-1/4" x 1/2" pcb with 3 caps, 2 diodes and an LT1054. I use it to get 18V power to some of my pedals. It can take up to 15V, so you can get up to 30V out of it. Pretty useful.
    -Ryan
  3. czech-one-2
    East of you
    Lots of folks run out and buy a new pedalboard power supply when they have to power an odd ball pedal. This is ALOT cheaper!
  4. RyanJH
    RyanJH Tele-Meister
    Did you actually measure the 6A output? Or are you just going by the spec? The spec indicates 0-4A in and 0-4A out. To me, that doesn't indicate that it'll boost the amperage; only that it can take in and output up to 4A, depending on the input amperage.
    -Ryan
    Edit: I see you've removed that portion of your reply?
  5. czech-one-2
    East of you
    Yeah, I deleated that immediately. I think the milliamps are the same as what you put into it? If it boosted MA it would truly be a must have.
    As it is you can just dial in any voltage you may need.Perfect for my 24v pedal.
    I wonder if somebody makes something similar that also boosts ma capacity?
