DC at the input 5f2a
Discussion in 'Shock Brother's DIY Amps' started by leebman, Sep 30, 2014.
  1. leebman
    leebman Tele-Meister
    England
    I have been noticing a lot of switch noise on my pedals, and so i measured the voltage at the input and there appears to be around 200mv dc is this normal in a 5f2a or is something going wrong ?
  2. muchxs
    muchxs Doctor of Teleocity
    New England
    Nope. You either have a bad ground somewhere or a bad 12AX7.
  3. leebman
    England
    I've tried 4 different 12ax7s with same results so I'll check the grounds and see if i can chase it down. Thanks
  4. tubeswell
    tubeswell Friend of Leo's
    NZ
    Some discussion on this in relation to TW amps (What plate voltage have you got on V1a?)
  5. leebman
    England
    Checked the grounds all are ok.
    thanks for the link tubeswell
    Voltages for 12ax7 as follows
    pin 1 190v
    pin 6 180v
  6. tubeswell
    NZ
    Well those voltages don't seem low to me. (shoulder shrug)
    Loose tube socket/pins? (retention the socket pin clips with a micro screwdriver)
    Or maybe someone else will have a another suggestion.
