Danelectro U2 Reissue Issue
Discussion in 'Other Guitars, other instruments' started by jrintheemaking, Nov 10, 2020.
  1. jrintheemaking
    jrintheemaking TDPRI Member
    Los Angeles
    I recently picked up a Dano U2 Korean reissue. Sounds and plays great although I am having an issue with it.
    The volume and tone work for both pickups. There seems to be an issue with selecting the different pickup positions though.
    For example, in the neck position you can hear the neck pickup and nothing else, as you should. In the middle position, you can hear both the neck pickup and the middle pickup, as you should. However, as you go from the middle to the bridge position, there is no "clicking over." Basically, there is no difference between the middle and bridge position. You should only be hearing the bridge pickup in the bridge position but you hear both the middle and bridge pickups. The goal is to correct this and hear just the bridge pickup in the bridge position, not both pickups.
    Does that sound like a solder joint, a faulty pickup switch joint, or something else?
    Thanks so much.
    DonM and Chiogtr4x like this.
  2. Warren Pederson
    Warren Pederson Friend of Leo's Silver Supporter
    Kelowna B.C., Canada
    Doesn’t the U2 have a push pull?
    Chiogtr4x likes this.
  3. jrintheemaking
    Los Angeles
    Hi. I’m not sure about other U2s, but this one has a 3 position selector switch, and two ‘complete’ knobs. Both pickups have a volume and tone, but it is combined into a stacked knob made up of two separate mini knobs. The volume makes up the bottom of the knob and the tone is on top of the volume. If you look at the pic I posted, it will make more sense.
  4. Chiogtr4x
    Manassas Park, VA
    Not mine
    It has a 3-wsy toggle for pickups
    And concentric Vol/Tone knobs for each pickups
    - I've had mine since '97 and I just spray DeOxit into the toggle switch ( from the top to make better contact, and just work the switch in all positions repeatedly
    Great guitar- full of tone Clean or dirty and so comfy!
    DonM, posttoastie and jrintheemaking like this.
  5. jrintheemaking
    Los Angeles
    My model is the same as yours.
    I’ve tried the Deoxit on both the selector and the pots. It actually helped with the neck position. It wasn’t working either but now it does. But the bridge position still isn’t working properly after a couple rounds of DeOxit...
  6. Chiogtr4x
    Manassas Park, VA
    Now that I think of it I do have the same kind of issue when I pick Dano up when it hasn't been played in a while,
    So just working the switch vigorously usually takes care of it- better contact on all 3 positions- it may just be a crappy ( not heavy-duty) switch?
    jrintheemaking likes this.
  7. Flip G
    Flip G Tele-Meister
    Kitchener ON
  8. jrintheemaking
    Los Angeles
    I’ve only had it a week or so. But from what I know about a lot of the reissues (because they are period correct) is a sinking/sagging bridge. Mine does have a bit of sag, but there are no playability issues.
    Flip G likes this.
  9. Deeve
    Deeve Poster Extraordinaire Silver Supporter
    Ballard
    No -
    ... but it does have
    Rattle & Hum . . .
  10. DonM
    DonM Friend of Leo's
    Oceanside,CA/SLC,UT
    I’ve had this one since ‘98. Had a Yellow DC and stupidly sold it.
