LaMarr-Bruister
I'm not sure what happened to my D string. Everything was great, the guitar was playing as well as ever and the setup has been dialed in for a long time. I changed strings last night and the D string is ringing on the first fret.
I used the same brand and gauge as I've used for the last 5+ years. I changed the D string a second time after opening a 2nd pack but the problem persisted. I've checked the relief, which is at my usual spot, but played with the truss rod to no avail just in case I needed to add a little relief. I slid a single PC of paper under the string and that's enough to get the string off the fret and make the ringing stop. It just seems odd that this coincided with a string change. I would've thought that if the nut was off I would have noticed before.
Maybe this is a reason to buy a set of nut files and fill that slot slightly and learn to cut the slot (it's been on my list of things to learn), but it seems like something else should be going on. The saddles haven't moved. It went from being dialed in completely to a disaster the moment I changed strings.
Is there something that I am missing that I should try? It seems unfortunate to replace a bone nut with a new one for a single string.
Any tips would be appreciated!
Thanks!
Thanks!
