kiwi blue
I recently got a used lefty MII CV 50s Tele with the idea of tweaking it towards blackguard specs. It was soon pretty obvious that I'd be replacing the pickups but first I wanted to play around with the bridge and saddles, as I like to get a guitar humming physically first, then tweak the electronic to work with the acoustic sound of the guitar.
I had a thinner bridge plate I wanted to try as it's closer to 50s specs, and thinner apparently gives a bit more twang. Plus I will need to remove the bridge at some stage to replace the bridge pickup. It's just 4 little screws right? Five minute job. What could go wrong?
Well these sods were done up so tight in the factory that I could only remove the two inner screws and ended up stripping the two outer screws. Very soft metal. I can only think the factory just shoves them in with high speed drills on max torque without any thought for being able to remove them down the line.
So I learned about screw extractors (new to me), went out and bought a set and a cordless drill. Set to work trying to extract them. Also tried other tips I came across online. Nothing worked. In the end the screwheads were pretty mangled so I just broke them off by levering the bridge plate. I was then able to remove the plate. That left two screw shafts with a little bit poking above the wood. I gripped them with pliers and tried to turn them but the shafts just broke off. Now I had no option but to excavate wood. I drilled small holes around the screws and chiselled out the wood between them so I had a roughly circular space around the screw. I had to go down about half the length of the screw before I could turn them with pliers, and even then I had to do some vigorous wobbling to loosen them enough so that they would turn. Now I'm faced with filling and drilling the holes I made, so that will be the next episode of this saga.
Am I grumpy? I lost a most of long weekend to this bull and ended up with quite a bit of unplanned spending of money reserved for other things, like staying alive. You bet I'm grumpy.
To me this goes against Leo's whole ethos and a basic design principle of the Telecaster. Anything on a Tele should be fixable/replaceable at the side of a stage with nothing more than a screwdriver and a soldering iron.
I realise Squier/Fender doesn't care one bit about the modders put there, but a Tele should at least be repairable if a pickup shorts. This is sub-par manufacturing. Beware.
BTW the serial number indicates the guitar was made in the Samick factory as one of the earliest Indonesian CVs. From what I've read it seems most are made by Cort.
A shame really, because the guitar does have real potential.
On the positive side I guess the pine bodies aren't so soft as I sometimes hear. Or maybe they are soft so they glued the damn screws in?
