Cutting speaker baffle holes?
Discussion in 'Shock Brother's DIY Amps' started by Little Ricky, Feb 17, 2009.
  1. Newt522
    Newt522 TDPRI Member
    South Carolina
    I find a jar lid of the proper size and screw it in the center of the hole(screwing through the baffle material into waste material below). A plunge router would work better; with a regular router you have to be careful not to cut the outside of the hole if you tilt it in. Also keep good inward pressure so it doesn't skate outward.
    (A lid from Felix lingonberries is the right size for Jensen P10R's)
    GoldDeluxe5E3 likes this.
  2. Killin5
    Killin5 Tele-Meister
    Here is what I whipped up for my trim router. I only needed a hole for an 8" speaker.
    I made a piece of wood to fit over a pivot pin and attached it to the edge guide that came with the router.
    It is helpful it you have the outer part anchored so it doesn't move once it is cut free.
  3. mungus
    mungus Tele-Meister
    York
    You can do this with a router bit, a piece of string, and a drill.
    Don't expect a perfect result though:
  4. Dave1234
    Dave1234 Tele-Afflicted
    Leicestershire
    Nor a full compliment of fingers?
  5. DesmoDog
    DesmoDog Tele-Afflicted
    SE Michigan, USA
    I have my router screwed to a board so its acting like a router table. Then I:
    Put a 1/8" hole in the center of the speaker baffle.
    Drill a ~9/16" hole in the baffle so that the furthest edge of the hole is right on the line I want to route.
    Put the baffle in the "router table" board with the 9/16" hole over a 1/2" router bit.
    Pull the baffle tight into the bit
    Drill a 1/8" hole through the center hole into the table
    Put a 1/8" pin into the hole (a drill bit works too) and then fire up the router and spin the baffle on the pin.
  6. mungus
    mungus Tele-Meister
    York
    All my fingers survived intact :) It really didn't feel dangerous - just not very precise. Good enough to be functional though, if you're careful.
  7. Blue Bill
    Blue Bill Poster Extraordinaire
    I've been using a Jasper circle jig for years. It's about $40, and a little fussy, but cuts perfect circles all day.
    http://jaspertools.com/
  8. mishagolin
    mishagolin Tele-Meister
    Atlanta
    A good jigsaw blade with the saw set for minimal forward excursion and go slow. Then I just use an 80 grit belt from a belt sander and clean it up by hand. Works good enough for me.
  9. mishagolin
    Atlanta
  10. ItchyFingers
    ItchyFingers Tele-Afflicted
    Ottawa Ontario Canada
    I just did a 13.87" one with a jigsaw freehand following a line I made with a piece of wood on a screw in centre and a pencil in a hole at the proper radius. Piece of cake. I touched up a few spots with a rasp and sanded the final product. A half hour spent in total at most. I'd do it just like that again and will. Safe, fast, easy and I didn't have to run around finding and setting up a whole pile of stuff. A router on a string? Yikes!!! scary stuff. I must say though, a lot of you are producing some mighty fine holes. There's some cool ideas in here.
  11. ItchyFingers
    Now that is cool. Other than the setup time, that is the best thing I have ever seen for making holes.
  12. perttime
    perttime Tele-Afflicted
    Finland
    The Jaspertools site launched a popup that requires login, and doesn't allow me to do anything else with the browser (Firefox on Windows 7). I wasn't willing to touch the popup, so restarted the computer.
  13. GuitarJonz
    GuitarJonz Poster Extraordinaire
    MA
    I ain't got no fancy tools, took a low tech approach. Last one I did, I pulled the chassis, cut the baffle to size, screwed it in the cab, replaced the chassis, laid it face down, placed the speaker where I wanted it (to get proper clearance from transformers, etc), traced the outline of the speaker with a pencil. Then took it apart, and with a compass, drew the smaller circle to compensate for the 1/2-3/4" width of the speaker rim. Then drilled a bunch of holes to edge of the inner circle, and cut the speaker hole with a handheld jig saw, sanded the cuts, and painted it flat black. Not rocket science.
  14. aerhed
    aerhed Friend of Leo's
    Boulder, WY
    I have a Cheney jig. It's a 28ga. Mod choke fixed to a drunk. You hold a piece of plywood at a specific distance with a picture of a lawyer on it and holler pull!
    jaybones and xafinity like this.
  15. jmp81sc
    jmp81sc Tele-Meister
    Orange County
    My neighbor belongs to an Urban Workshop, which is a membership type shop with all of the cool tools.
    They use water jet cutters to cut plywood. Perfect cuts for complex shapes and repeatable.
  16. OpenG Capo4
    OpenG Capo4 Friend of Leo's
    Athens, GA
    Holy back from the dead Batman
    But I made a circle cutting jig. Basically a strip of plywood with the router bolted to it and a hole for a pivot pin or screw at whatever radius distance from the outer edge of the cutter.
  17. OpenG Capo4
    Athens, GA
    Works for making cornhole sets too.
  18. Henry
    Henry Tele-Holic
    Where am I going to find a beaver in Australia...
  19. Mr Ridesglide
    Mr Ridesglide Friend of Leo's Silver Supporter
    Bloomington, MN
    I take a nail. I drill a hole in my jigsaw guide. I drill a couple holes on the circle I've drawn. Then I put the guide over the nail. Adjust length of jigsaw guide to proper distance from nail. Plug in jigsaw. Go!
  20. jaybones
    jaybones Friend of Leo's
    Kelleys Island, Ohio
    Maybe a platypus would work in a pinch?
    Or go ask Sheila.
