That thing about wood killing bacteria is apparently based on a paper written by someone (forestry industry or some such) in Wisconsin that has been pretty thoroughly debunked. The author himself said that professional laboratories had been unable to duplicate his results, but he pointed to some high school science fair projects that seemed to support it; not something I'd really put a lot of faith in.Those commercial kitchens are way cleaner than most home kitchens. And they're throwing everything into heavy duty washers.
Plastic and glass hold bacteria. Wood naturally kills bacteria ... to some degree.
Have to clean the plastic and glass more so than wood.
Or so I've heard.
That's because idiot health inspectors have been told that wood is a fail even though studies suggest it should be the other way around. End grain on closed grain woods is best species beyond that not much of a factor.I have done work in most of the high end restaurants here as well as the next tier ones. Not 1 wooden cutting board. Most are a white material (poly/nylon?). Some are the green like mine. Easy to clean & sanitize. Every professional chefs I know keep their knives sharp and I’ve not heard any of them complain about their knives being damaged
The top picture is the cherry sideboard I built a long time ago. THIS is the Voodoo Coffee Bar.I recognize the top picture as Coffee Island.
The top picture is the cherry sideboard I built a long time ago. THIS is the Voodoo Coffee Bar.View attachment 1369123
A couple times a year I’ll glue up all the hardwood cutoffs from my cabinet shop and knock out a few boards. No two the same, made mostly from maple, walnut and cherry.
Yup. A paper towel will do in a pinch. I have a rubber mesh thingey. It needs a regular washing too.In the home kitchen, we've had/used white plastic, which has served us well, with one exception: they tend to slide around on the counter when we're trying to cut stuff on it. My wife, the trained, Registered Dietitian, retired, came up with an easy solution- spread out a damp dishrag on the counter and put the cutting board on it, no sliding! Works with wood, too!
Much better than the cherry sideboard I built from scratch? Sheesh!Ah, yes! A much better bit of furniture. We're Arts & Crafts fans in this household.
Please come back and let us know what you think.We just changed out to a titanium cutting board.We haven't used it yet.
I'm probably already full of teflon and plastic.
True about the sunlight- it's mostly the UV; in fact UV lights for sterilizing toothbrushes are kind of a thing, and they're fairly effective. I'd be pretty careful about leaving a board in the sun, though, it could warp pretty fast, and a cutting board that's not flat is no fun.Ok, I worked in a restaurant.
As a practical matter, though, all the food processes in a restaurant are on a much larger scale than what I do at home. Might use a cutting board once or twice a day, rarely three times and it’s just not a large volume. Just isn’t.
Wood works fine at home. I clean the two that get used after finishing. I now live in a dry sunny climate, so haven’t experienced any negatives. Sometimes, I’ll put a dry board out in the sun - yep, sunlight disinfects.
But sure as I say that, some person will start up with, “Well, actually blah, blah, blah.
Commercial kitchen practice ain’t the same as home use.
You mean 1.) the health inspectors who happen to be idiots or 2.) that all health inspectors are idiots ?
I’m sure there are some of #1 but I’m completely done with that #2 line of thinking .
Good catch! I actually had to go back and revisit how I worded that. Especially as I know two fellows who do food health inspections! No it comes down to the rules that they have to enforce. Not all the rules but the ones that deal with cutting boards and other things are allowed to fly that shouldn’t.You mean 1.) the health inspectors who happen to be idiots or 2.) that all health inspectors are idiots ?
Also useful when using a sharpening stone.spread out a damp dishrag on the counter and put the cutting board on it, no sliding! Works with wood, too!
What if you have a curvy blade knife?True about the sunlight- it's mostly the UV; in fact UV lights for sterilizing toothbrushes are kind of a thing, and they're fairly effective. I'd be pretty careful about leaving a board in the sun, though, it could warp pretty fast, and a cutting board that's not flat is no fun.
Try bench cookies! Those things are the bomb for cutting boards,bread boards or just boardsAlso useful when using a sharpening stone.
Thanks for the tip. Seems like overkill for this situation. Maybe if I had more tools and an in-home shop.Try bench cookies! Those things are the bomb for cutting boards,bread boards or just boards
