I've done quite a few electric guitars over the last few years (of various quality
), however I always used templates for the neck and body for each of the guitars. I've varied the shape of the guitar body sometimes, but I still used templates for pickups and neck pockets.
I'm planning on doing a 4-string tenor guitar with 20" scale and I don't have any templates for that. My approach is the following, and my questions are in bold:
1. Calculated neck length for 20 frets using https://www.stewmac.com/fret-calculator/
20th fret is at 13.70" so I will round it to 14" total length from nut to end of neck, to allow for some space after the last fret.
2. My understanding is that the 16th fret is where the neck meets the body, which is at 12.063", so the neck pocket length will be 14"-"12.063 for roughly 2".
3. For the nut width, I want same string spacing as on regular tele, so I will just measure the distance between A and B strings on a standard tele nut and give it some additional space at the top and bottom strings. This will give me the neck width at the nut.
4. I have a 4 string bridge, but I'm not sure how to determine the neck pocket width and taper, given the scale, neck width at nut, and bridge width between 1st and 4th saddle.
Should I just draw it precisely to scale, or is there a better approach?
If I go to the draw-to-scale approach, and use the drawing to cut the neck, how do I cut the neck pocket to match the neck heel?
5. What length truss rod should I use for 20" scale?
6. Should I aim for 1" neck + fretboard thickness, like on regular guitar?
Any comments on my plan above will be highly appreciated.
Thanks for your help!
Peter
20 | 13.700" | 0.375" (19-20) |
16 | 12.063" | 0.472" (15-16) |
Peter
