Custom Printed Circuit Board?
Discussion in 'Tele-Technical' started by youdevil, Oct 21, 2019.
  1. youdevil
    youdevil TDPRI Member
    Wayne, PA
    Do you know of anyone who can design and produce (in low quantity) a custom printed circuit board? I've got a bunch of components to connect up inside a control cavity and it would be MUCH easier to do if i had such a thing.
    If you have alternative suggestions - a micro 'patch bay'? - I'm all ears :)
    Thanks -
    Chris
  2. Blrfl
    Blrfl Tele-Holic
    Northern Virginia
    There are scads of outfits like Advanced Circuits and Pad2Pad that will take an order online, fab the boards and send them to you.
    The expense in doing a custom board is in the setup, so see how the quantity breaks work for you. It might be that ordering a dozen ends up costing the same as doing one.
    Depending on the guitar and your application, Tone Shapers has a bunch of pre-made kits with DIP switches that will let you set pot resistance, tone control capacitance and a few other things. I have on in my '73 and like it.
  3. TimTam
    TimTam Tele-Holic
    Melbourne
    Or you could do it yourself the way that many people learnt small-circuit PCB making - with a piece of prototyping veroboard (cut to the size needed with a sharp blade) and a track cutter. You just plan the best layout and then mount your components (including any track-linking wires needed), cut a break in any tracks to separate any components that need separating on the same track, and then solder. If it works, you're good to go. Or you trouble-shoot it.
    You could breadboard the layout first if you want ...
  4. RodeoTex
    Nueces Strip
    I did a couple of fairly simple boards myself using the copper PC blank boards and etching fluid.
  5. youdevil
    Wayne, PA
    thank you all for these! very helpful.
  6. LetItGrowTone
    LetItGrowTone Tele-Meister
    U.S.
    I successfully built an RF preamp on a perf board (no copper on either side) by just sticking the components through and twisting the leads together on the back. I was just lucky I guess, as RF is very demanding. But I don't doubt it would work in a guitar.
