radtz
I'm doing a refresh on my Warmoth Rhodes V style axe. I installed and set-up a new bridge and it plays fantastic.....until I plugged it in. The wiring needs a refresh. I've got a SD single coil (I forgot which one) at the neck and SD Invader HB at the bridge. The point of this guitar was for metal but with ability to switch to the neck for a sweet clean sound. The wiring is all jacked up (sound is bleeding through with volume off, highs cut out). I think the toggle and output are wired OK but I may as well just start over and rewire it.
What we have to work with:
1 4 wire Invader humbucker (passive) - bridge
1 2 wire single coil - neck
1 push/pull 500 K pot for volume (new)
1 mini 3 way toggle (or I can replace it with a Gibson style full size 3 way)
Output jack
No tone pot
(I could replace the neck pickup with a Chinese hotrails I have for 2 HBs)
I don't want a tone pot and I want as much high end and output as I can get out of the Invader, and I don't much care about the neck pickup. The toggle is for pick-up selection (bridge/both/neck). I'm sure I wired the push/pull to do a coil split on the HB, but I don't need that anymore. That said, the push/pull should be wired to do something. I could add a tone pot (for the single coil) but I'd rather not. The point is to use the bridge pickup full on 95% of time. I have no issues rewiring the toggle either.
I'm looking for both suggestions on the best way to wire this, as well a schematic so I can wire it right. Maybe something creative I haven't thought of???
Output jack
No tone pot
