CS Texas Special Neck Pole Piece ...
Discussion in 'Just Pickups' started by xuoham, Jan 25, 2020.
  1. xuoham
    xuoham TDPRI Member
    Okinawa/Japan
    ... are they staggered or not ?
    I've had enough with the wooly / ice pick unbalance of a neck P90 and a bridge single coil on my mahogany Tokai tele, and i have a chance to get a CS Texas Special set for cheap.
    My deilemma is that i use a wound G and i am afraid of string unbalance if the pole pieces are NOT staggered.
    Since it seems impossible to remove a tele neck PU cover ...
    Thanks guys for any info.
    Cheers
    Fretting out likes this.
  2. Irondog
    Irondog Tele-Meister
    San Francisco, California
    get the Texas specials, Texas specials are extremely nice, and perhaps stop using a wound G?
    The B string is where the stagger seems to be. G string is definitely quite bright in general,
  3. xuoham
    xuoham TDPRI Member
    Okinawa/Japan
    Thanks but i think you misread.
    I am talking about the NECK pu. ^ ^
    I know Texas specials and i love them.
    I just want to know whether the hidden pole pieces of the neck pu are staggeredt or not.
    Regarding G strings, if you use a .019 from Thomastik, you stilll can bend and live in happiness regarding intonation.
    i am more into jazz and funk than rock and country. That's why i'm a convert with the wound G, but it's a different debate anyway.
  4. dougstrum
    dougstrum Tele-Afflicted
    blu ridge mtn cabin
    TX special neck cover can be removed, with care to keep the tabs away from the windings.
    The pole pieces are indeed flat.
    xuoham likes this.
  5. xuoham
    xuoham TDPRI Member
    Okinawa/Japan
    Thanks a lot Dougstrum !
    dougstrum likes this.
  6. dougstrum
    blu ridge mtn cabin
    Probably not worth the trouble/risk of removing cover. The sonic difference is minimal.
    xuoham likes this.
