Creaky truss rod
808guitar
Hawaii
The truss rod on my Squier Tele Deluxe creaks when I tune the G string or bend the G string. The guitar is 10 years old or so and just recently started doing this. It adjusts fine. Do I need to be concerned, and can I do anything about the noise?
boredguy6060
Sou Cal
Never heard of a truss rod creaking because of tuning or bending.
The nut slot, especially the G sting slot is a common cause of pinging, and creaking and it’s worse on a wound G string.
Try some graphite ( pencil lead ) in the slots and see if it improves, if it does, there’s your answer.
808guitar
Hawaii
I'll check those out today. It sounds like it is coming from inside the neck but I've got musician's ears so my hearing is definitely suspect.
808guitar
Hawaii
Thanks, you were all correct, a little graphite in the nut and the creak went away. Now to get my ears looked at...
