'Creaking' G string
Discussion in 'Tele-Technical' started by Thorpey, Nov 7, 2013.
  1. Thorpey
    Thorpey Tele-Holic
    Blackpool, UK
    When I bend on the g string it makes a sort of creaking sound... Have any of you tech whizzes experienced this? Is there a solution?
    Any help would be gratefully received!
  2. PinewoodRo
    PinewoodRo Tele-Afflicted
    Carmarthenshire, Wales.
    Getting hung up in the nut slot? Does it creak or 'ping' as you tune up that string? Solution is to file or polish the nut slot. (a wound string of the correct guage can make a good filing/polishing tool). Another cause could be a scratch on a fret somewhwere. Just enough to catch the string a bit when you bend - sand 'em smooth...
  3. Thorpey
    Thorpey Tele-Holic
    Blackpool, UK
    Would lubricating the nut slots be worth a shot? Saddles too? Could well be hanging up as yeah it sometimes does that ping when I tune up!
    What kind of everyday stuff can you use to lubricate contact points?
  4. SteveO
    SteveO Tele-Holic
    New Jersey
    You can use a pencil. Just sharpen it and rub the point in the nut slots. Pure graphite, a pretty good lubricant and cheap as chips.
  5. PinewoodRo
    There you go - definitely worth a try first, great tip, ta.
  6. Thorpey
    Thorpey Tele-Holic
    Blackpool, UK
    Got plenty o' those lying around! I'll give it a try and get back to you! :)
  7. SPUDCASTER
    Grangeville, Idaho
    Chapstick, run it across the whole nut and work it in.
    Also check the neck screws/bolts. Sometimes it they aren't snug, you'll get some creaking.
  8. sparkletele123
    sparkletele123 Tele-Meister
    London, UK
    I put a roller string tree on a Guitar that did this and now its fine.
  9. steveneddy
    steveneddy Tele-Meister
    Big Bends Nut Sauce
    Been using this stuff on nuts and string trees and bridge saddles for years.
    A little goes a long way - solves tuning and creaking issues!
