Badside
So yeah, this is a bit over the top, some would argue totally unnecessary.
But I was talking with a guitarist friend who is running an amp head that I believe is sort of a Blackface front end into a pair of cathode biased EL84 (haven't opened it up yet, but it's 2 12AX7 and 2 EL84 into a 8.4k OT, and it has Bass and Treble control and no MV).
He loves this amp for lead (and it does have a lovely compression at band volumes) but he also wishes he could get more headroom for rhythm work or clean tones.
This got me thinking... Now, switchable power levels is not a new thing, it's been done before. Either through a Pentode/Triode switch, by changing between Fixed and Cathode bias, by changing the plates or screen voltages, etc. But every amp I've tried with multi watt options always sounds the best on full power. Because all these strategies fail to address one big difference between a small and a big power amp: the output transformer and the power supply!
When you switch a 50W head into a 10W mode of some kind, you're still going through a 50W OT and getting the full capacitance of the 50W power supply.
Yes, it distorts at a lower volume, but it just turns the power amp into a distortion box. It does not get you that "amp is struggling to keep up" lovely compression where single note lines because as large as power chords.
Amplifier switchers are a thing, they're actually very simple: see if you mute one amp then you can just send it's output to ground (or some largish resistor) because there is no sound coming out. The OT only carries AC, not DC. So if the amp is muted, the OT barely cares what's on the other side. A ground reference is preferable of course, but at best there will be a tiny low level noise going through. There's no need to dissipate watts of power.
What if I translate that into a single amplifier, with a shared preamp and power transformer, but two different power amps. A low power cathode bias EL84 pair (like his current amp), and a higher power fixed bias 6L6 or similar power amp.
So here's where I'm at (ignore the preamp for now, I'll tweak that later)
So what we have is a low-ish voltage PT with high current capability. Using the 125VAC primary, B+ should be around 345-350VDC (based on my 272FX getting 375). This is a nice voltage for 5881, so reconducting the power amp from my "Brownvibe" build for the high power side. Should net around 30-35W with a firm low-end. My Brownvibe gets a lot louder than I expected it to be (but it does have an extra 30VDC to work with)
Now for the low power side, take that 345VDC and run it through an EZ81 to bring the voltage down to safe levels for the EL84 and add the desired "sag". Combined with much lower filtering.
How the switching works:
Two relays are necessary, one of which has to be rated for high current (around 6A if the high power side is ran at full tilt)
Relay 1A - Takes the preamp out and either send it to the High Headroom PI or the Low Headroom PI (both PIs have a reference to ground to prevent popping)
Relay 1B - Ground the PI input of whichever side isn't being used (this is to ensure almost nothing comes out the other end)
Relay 2A - Takes the OT output of whichever side is in use and sends it to the speaker output
Relay 2B - Ground the OT output of whichever side isn't in use (again, because that power amp is muted, there is no AC to dispose of)
CHALLENGES:
What I'm worried about though is that during the switching, at some point the speaker output is lifted, and it's at that point a pop is most likely to occur which could send a big jolt through the OTs. That's why I put a 120R resistor across each OT secondaries, so they never go full open. But unsure if this is enough...
Maybe if I can find a "make before break" relay, that could work (the OTs would be in parallel for a fraction of a second, but that is not really an issue).
If I put two preamps (which might be preferable actually, but adds a 9th tube), I could just shunt to ground one preamp at a time without having to hard switch the output, which would prevent any popping.
Also, I really wish I could get the High Headroom side into the 400+ volts range, but that would require dropping a lot more Vs for the Low Headroom side, which means dumping a bunch of heat. Short of getting a custom wound PT (or putting in a 2nd one), I guess I have to make that compromise.
Last crazy idea: kinda want to figure out a way where if I plug in a 2nd cabinet, then I can use both sides at the same time (switch between just Low and Low + High)
CHALLENGES:
