crate footswitches
Discussion in 'Amp Tech Center' started by bobj65, Feb 15, 2020.
  1. bobj65
    bobj65 NEW MEMBER!
    Attleboro ma
    Hi was wondering what footswitch I would be able to use on my crate gx212 amp? thank you
  2. Lowerleftcoast
    Lowerleftcoast Tele-Afflicted
    california
    Are you looking to build a footswitch for your gx212?
  3. control voltage
    control voltage TDPRI Member
    3rd from the Sun
    The original one had 3 buttons, as described below, but you could probably use a one-button type with a mono 1/4" plug for the reverb, and a two-button type with a stereo 1/4" plug for the channel and gain. Or, something like the Ampeg AFP-3 might work.
    Here's a link to the owner's manual page that covers the footswitch:
    https://www.manualslib.com/manual/33038/Crate-Gx-212.html?page=5#manual
    21: CHANNEL SELECT / GAIN FOOTSWITCH
    JACK (rear panel, not shown): Use this jack to
    connect the 1/4" stereo plug on the footswitch
    cable to the three-button footswitch (supplied).
    This allows you to remotely switch between the
    Clean and Overdrive channels and between
    Gain 1 and 2 of the Overdrive channel.
    22: REVERB FOOTSWITCH JACK (rear panel,
    not shown): Use this jack to connect the 1/4"
    mono plug on the footswitch cable to the three-
    button footswitch (supplied). This allows you to
    remotely turn the reverb on and off.
    The one Crate provided for it looks like this:
    Fretting out likes this.
  4. Jon Snell
    Jon Snell Tele-Meister
    Jurassic Coast. UK.
    I wonder why there are three switches, the GX-212 only allows for Chanel Select and Shape on a TRS lead.
    The foot pedal looks just like the Marshall one ... I may be wrong but the amplifier has only provision for the two selections.
