Crackle on intensity pot Vibro champ
Discussion in 'Shock Brother's DIY Amps' started by Linkjr, Mar 14, 2021.
  1. Linkjr
    Linkjr Tele-Meister
    Uk
    Hi Guys,
    I got some crackle when turning the intensity pot up on my Vibrochamp it happens only from settings 1-5 and doesn't matter if the tremolo is active or not.
    any ideas what could be causing it? i got a lovely deep tremolo but i am led to believe this symptom could be caused by dc on the pot.
    Could the cap on pin 8 of v1 have anything to do with it?
  2. D'tar
    D'tar Friend of Leo's
    WNY
    By design.... You will ALWAYS have DC on the intensity pot.
    Phrygian77 likes this.
  3. schmee
    Have you sprayed inside the pot? It could just need cleaning. Not uncommon at all. Failing that you may have to change out the pot.
    SnidelyWhiplash likes this.
  4. Phrygian77
    Crawfordville, FL
    ^^^ This!
  5. Linkjr
    Linkjr Tele-Meister
    Uk
    Thanks guys , am definitely from the simple things first school of thought tried cleaning i will try to swap in another pot.
    Just out of interest besides faulty or dirty pot what else could be a likely cause?
    the pot is new and amp has not been used much definitely did not have this problem when I put it in.
  6. Linkjr
    Linkjr Tele-Meister
    Uk
    Update have swapped out the pot, on the new pot no crackle - problem solved
    But the original pot was new and of a high quality I opened it up see below does this look right ?
