Took torch to bare body to pop some grain in the basswood. No where near the heat for Shou Sugi ban type of finish.
Small crack appeared in glue joint. Current plan is to heat up body and epoxy a bit to thin out, and dribble it in the crack.
Would this be a decent solution? Not sure I want to slice it apart at the seam and clean glue surfaces/reglue, since this is a relatively cheap body blank.
