Could somebody with wiring skills check over these diagrams for me?
Discussion in 'Tele-Technical' started by eddnix, Aug 11, 2019.
  1. eddnix
    eddnix Tele-Meister
    Leeds, UK
    Hi there,
    Walking home from the supermarket a few weeks ago I came across a beaten up Squire Tele Affinity in a skip and have spent the last month or so souping it up. So far I've refinished the body with fabric and nitro, attached a new neck and vintage style bridge with brass compensated saddles as well as converting it to string through body. I've purchased a set of Tonerider Hot Classics so next up is the wiring! As it was a freebie I've been going a bit potty with mods and learning loads along the way and in such spirit these are the schemes I've come up with, what I require and would be most gracious for is for somebody to check over these diagrams and give me a bit of input on them.
    Firstly there's this 4 way switch with with DPDT switches diagram for OOP with a "Bright Switch":
    After drawing that one up I came across the Freeway 6 way lever and came up with this:
    The second one is the design I prefer but will adding the .01 cap on the DPDT switch for Hoop work or have I got it horribly wrong? I've deepened the control cavity before I shielded it by 3mm so the switch should fit. Any input would be gratefully received!
    Edd
  2. sjtalon
    sjtalon Doctor of Teleocity Ad Free Member
    Upper Peninsula of Michigan
    eddnix likes this.
  3. eddnix
    eddnix Tele-Meister
    Leeds, UK
    You are correct! The wiring diagram distributed by Freeway suggests adding the 0.01 cap directly into the circuit between A and NG for HooP. What my diagram is attempting to do is allow me to add in the cap at will to get the two out of phase options to be half out of phase when the DPDT switch is on "pull". Being a bit green with wiring schematics I'm not too sure it will work, drawing these up made my head spin!
  4. eddnix
    eddnix Tele-Meister
    Leeds, UK
    My head will probably spin even more when attempting to use a guitar with this many options - but this exercise is more about learning something new than how "easy" to use the guitar will be when completed ;)
  5. eddnix
    eddnix Tele-Meister
    Leeds, UK
    Ah, very nice! Thanks for the link! I should be able to edit the design with a touch more confidence using your switch with the resistor! I was worried the switch might be a bit clicky!
  6. Norris Vulcan
    Norris Vulcan Tele-Afflicted
    Somerset, UK
    1. Who throws a Tele in a skip ? :eek:
    2. You're putting a 'bright' switch in a Tele ? :eek:
    Piggy Stu and eddnix like this.
  7. eddnix
    eddnix Tele-Meister
    Leeds, UK
    I know, i saw the headstock sticking out and my heart skipped a beat! As for the bright switch, it may not stay in there - from my understanding of it the mod makes the the tone and volume act like no load pots. If I'm wrong me and my newly acquired tinnitus will update this thread later ;)
  8. eddnix
    eddnix Tele-Meister
    Leeds, UK
    Okay, after some fiddling around with DIYLC I've discovered that the cap on the DPDT switch wouldn't work at all and I'm too simple minded to work out another solution. I'm going to track down an S1 and go full Baja. Consider this thread dead and anyone stumbling across it for wiring ideas should disregard that second diagram!
  9. jvin248
    jvin248 Poster Extraordinaire
    Lions & Tigers oh Mi !
    Very few players use the S1 switch on the Baja. Many use the 4-way.
    If you put quick connectors (someone recommended RC hobby car plugs off Amazon before) you can build up a couple different controls on loaded control plates and swap back and forth easily.
    eddnix likes this.
  10. eddnix
    eddnix Tele-Meister
    Leeds, UK
    That's a fine idea!
  11. eddnix
    eddnix Tele-Meister
    Leeds, UK
    Right, sorry for continually bumping this thread but I've had a breakthrough. This is what I'm going with and have just ordered the parts:
    That fried my poor brain. The idea is a typical 4 way OOP set up but with the ability of pulling the tone and getting the HOOP cap and resistor in series. Tried it out in DIYLC and all seemed good. The interesting bit will be what will the HOOP components do to the tone when OOP is not selected? Looking forwards to finding out!
    Thanks for all your help good forum bods!
  12. sjtalon
    Good deal, I rigged my CV Thinline up with a 4 way and the HOop p/p (tone pot) like you have there. Nice option the HOop, kinda cool tone.
    Do keep us posted.
  13. sjtalon
    Forgot one thing.
    Sometimes common issue with 4 w installs is the slot in your control plate not allowing the lever to travel all the way.
    When you have it all set, take a paper clip and tap on the pups as you go through all the positions to make sure the proper things happen. You can hear the series as it will be a darker or muffled tap, vs. the reg. parallel (position 2).
    Sometimes if there is an issue, you can loosen the switch mount screws and with the slop in their holes move
    it to get clearance. If not, file the slot a tad longer with a fine tooth hacksaw blade.
  14. eddnix
    eddnix Tele-Meister
    Leeds, UK
    Top tips there sjtalon. Hopefully all will go swimmingly, if not I'll dig out a hacksaw blade! You're a star.
  15. eddnix
    eddnix Tele-Meister
    Leeds, UK
    'Tis wired up and sounds great, thanks for the input. It produces some interesting tones, especially being able to pop the cap and resistor in at will whenever the neck pickup is selected using the tone p/p. Not too sure how useful they are going to be but I'm looking forwards to finding out. I'll post a pic or two up of the finished build in a more appropriate place on the forum at some time in the near future. Once again, thanks people!
  16. tfarny
    tfarny Friend of Leo's
    Hudson Valley, NY
    Glad you got it working! I am about to remove a HOOP scheme from my Reverend and put in something that works better for me, but different strokes, etc.
  17. sjtalon
    Spectacular !
    Happy pickin'
  18. eddnix
    eddnix Tele-Meister
    Leeds, UK
