one clarification I would like to make to my OP. Thinking about this. My main question is how do you convince an electron to go to ground? Isn’t ground negative, and negatives repel each other. Not quite. The ground is not really negative. Ground is neutral and made up equally of positive and negative charges. Although ground is not the electrons first choice, the electron does not really mind going to ground.
and additionally, there is no reason why rectification cannot be described in terms of ohms law. The maxwell equations fully define all facets of electricity including electro magnetic forces and potential, but even they are based on ohms law.
I believe everything I wrote in the OP is true.
I believe the full wave SS rectifier, as used on the bassman, would actually function if the secondary winding was grounded at the end of the winding instead of in the ceneter.
I see a basic misunderstanding of simple DC circuitry. Electrons are negatively charged and when presented with an imbalance of positive and negative charge will seek the balance. Balance stops electron flow. Electrons do not flow through a battery, they flow from negative to positive and as long as the positive is in excess the electrons will flow. That is current. Eventually enough electrons are stripped away from the negative side that the battery stops working. When Ohm's Law was devised they did not understand fully how current flowed and got it backwards, so, as a rule, it is stated that current flows opposite the actual direction of the electron flow.
The diodes attached to the HV secondary of TR1 are not a full bridge.The signal passes through two 7025 tubes before feedin into the 12AT7 twin triode. Each side of the triode feed a control grid of a 6L6GC tube in a push-pull fashion. The incoming signal first turns on one side of the dual triode which in turn fires off it's companion 6L6. the 6L6's are tied to opposite ends of the primary of TR3 which converts the HV signal into low voltage current to drive the speakers.The little white triangles are a common signal ground. The HV secondary is connected through the chassis to the common between the 6L6 tubes completing the circuit. Remember, AC voltage/current travels in both directions before it goes through the rectifier. Electrons flow up through the ground into the 6L6 tubes toward the HV supply, first through one tube and then through the other.How does a full wave rectifier cause electrons to go to ground? When ohms law informs us that electrons are attracted to high voltages?
I believe these are the pieces and their functions in a full wave rectifier.
the secondary of the PT has high voltage AC on it.
on the AA864 bassman it is 305 + 305 = 610 VAC.
each end of the secondary is connected to a diode bridge.
the diodes are oriented so that electrons can only travel into the secondary, never back out, reversing course across the diode bridge.
The AC on the secondary brings electrons in from one bridge in one direction, and then brings in electrons from the other bridge, in the other direction.
some how, the electrons in the high voltage secondary, appear to go to ground when they reach the center tap, but why?
610 VAC divided by root 2 gives an ideal 431 VDC available using ss diodes, avoiding rectifier tube voltage drop.
the plate is at 425 DC, and so therefore it is anticipated that electrons at 425 DC are going to be willing to travel towards and to the 431 VDC produced by the solid state rectifier.
that explains how the electron arrives at the SS state rectifier, using ohms law. But what happens after that?
the electron is sitting at 431 DC, the idea is that the AC on the secondary is going to encourage the electron to cross the diode bridge, travel through the secondary winding, and decide that ground is a good place to be.
could somebody please explain, using ohms law, why the electron at high voltage decides to go to ground?
the AC is making use of the diodes and it’s own electrical energy to pump electrons into the ground. That much is clear. it is like the ground is a sort of trap. The electron has no reason to want to go there, but once placed there, it is unable to escape. View attachment 976715
I am not looking to start anything, but if you want to start another thread to discuss, I share what I know and you can tell me where you disagree. I would like to know where you disagree.I respectfully disagree with some of your statements. Unfortunately this thread has gone off the rails (was it ever on the rails?). I’m willing to learn a thing or two. Happy to start another gentlemen’s thread if you want to pursue it further.
Yes, it is why AC transmission is known as standing waves. Trying to simplify explanations for such forums and not write a white paper always leads to more questions anyways -- probably beat this horse enough.@popcat I think you put it succinctly in your post #3 (https://www.tdpri.com/threads/could...ctifiers-using-ohms-law.1099413/post-11345856 ), and @andrewRneumann I think you also have touched on the confusion with (and importance of) EMF. (OTOH, I think the ground concept is important but not quite at the center of the question here. The same results occur regardless of which node is chosen as ground.)
In the spirit of 'there are no dumb questions,' I gave this some more thought about the basic question of why things keep going in a circuit and how to explain it.
The overview in the Wikipedia page notes the definition of electromotive force: An electromotive force causes charge separation that then leads to the potential difference seen at the terminals of the source (e.g. a battery or a transformer secondary). For a battery, the charge separation is caused electrochemically when it's charged, and in coupled inductors (secondaries) it's caused electromagnetically by the changing magnetic flux from driving AC current into the primary. (@andrewRneumann mentions this in his post.)
So @peteb 's question in the original post kind of hit on this basic question/concept of why things keep going in the circuit. In this case, the AC current from the generator way back at the power station induces EMF in the secondary, causing charge separation and continually providing the energy to do the work of keeping the charges moving (work = energy = force on something moved through a distance in an opposing field). This this continuing, periodic charge separation that leads to the potential (voltage) difference at the secondary, and those separated charges are the ones the keep moving around to get back to a lower overall state (electrons toward positive potentials).
(This reminded me of what my high school electronics shop teacher used say. Since it's AC, the electrons really are just pushed back and forth. "You're not buying electrons from the power company. The same electrons that were in your TV when you bought it are still there.")
Electromotive force - Wikipedia
en.wikipedia.org
Also, here's a decent online text on EMF, Faraday's Law, more history of the early experiments, etc.:
23.5: Faraday’s Law of Induction- Lenz’s Law
Faraday’s experiments showed that the emf induced by a change in magnetic flux depends on only a few factors. First, emf is directly proportional to the change in flux ΔΦ. Second, …phys.libretexts.org
Two unlike materials in a solution (electrolyte) creates ions. The ions create a buildup of electrons on the anode. This is not taking the electrons from the cathode and pushing them through to the anode. It is a chemical reaction between the unlike materials creating ions that completes the circuit. The electrons themselves do not move through the battery. At a certain point the unlike materials can no longer create ions and the battery dies. In this sense I referred to the stripping away of the electrons. In fact, what actually happens is a balance has been reached no longer allowing electron flow due to chemical changes within the unlike materials. This is how I understand it.
Yes, current is often discussed as counting the electrons that move past a point in time, but really it's the amount of charge that's moving that defines the current, not the carrier (1 ampere = 1 coulomb of charge per second).Ok I read this fascinating blog
https://www.comsol.com/blogs/does-the-current-flow-backwards-inside-a-battery/
And it turns out you are right. The electrons do not complete the circuit. The circuit is completed internally in the battery by positively charged cations migrating in the conventional current direction. So I think I just took the abstraction a little too far. The abstraction that a battery is nothing more than a DC voltage source with a small internal resistance in series, although useful for correctly analyzing a circuit, should not be taken literally as far as electron flow goes internally in the battery.
The question still remains—why do the positive cations migrate from negative to positive? The blog post, which I admittedly didn’t fully comprehend, explains the chemical process that produces this result. I learned that electrical current is not always produced by moving electrons (easy to forget). It can be produced by positively charged particles moving just the same. Very interesting and thanks for pointing out my error.
Thanks SRHmusic.Since I had a similar simulation laying around, here's a bit more that might help illustrate the operation. This has a simple transformer model with a tapped secondary, just like the highlighted section of Leo's schematic in the OP. (The full wave bridge examples above are good, but not exactly corresponding to the schematic in the OP.)
