Converting Stainless Steel Hardware to Gold
Discussion in 'Tele Home Depot' started by gb Custom Shop, Mar 21, 2021.
  1. gb Custom Shop
    gb Custom Shop TDPRI Member
    Winnipeg, Canada
    Hi Folks!
    I'd like to take a stab at trying to convert some brushed stainless steel hardware to have a gold appearance. It seems there are a few different ways of doing this - the easiest being to just buy gold hardware in the first place! But I'm up for the challenge, and don't really care if it'll be more expensive in the end, and just want to have some fun with this project.
    What would you guys suggest for making stainless steel have a gold appearance?
    Here is what the piece looks like:
    https://tlcguitargoods.com/en/nek-plaat-rvs-music-man-stijl.html
    On a side note, if anyone knows where to buy a gold version of the above link let me know ;)
  2. old wrench
    old wrench Friend of Leo's
    corner of walk and don't walk
    The only thing that comes to mind is to have it gold-plated.
    You can get stainless to show a yellowish or straw color by heating to the point where those colored oxides appear on the surface, but I don't think that's the color or effect that you're after.
    Most (probably all) the gold guitar hardware I've seen looks OK at first, but it gets pretty ugly after some use.
    Maybe that could be avoided with a first-class gold plating job?
  3. Ronkirn
    Ronkirn Doctor of Teleocity
    Jacksonville, FL
    and if you DO decide to have it Gold Plated.. wear your pants with the deep pockets..
    r
    Steve Holt, bender66 and old wrench like this.
  4. blowtorch
    Wisco
    Give that guy Midas a call
  5. charlie chitlin
    Kimberton
    Get a philosopher's stone!
    It's been awhile, but I recall hold plating being inexpensive.
    It's only a few microns thick.
    I suppose you could gold plate a school bus with an ounce of gold.
    Try Caswell plating to see if he has a DIY kit.
    The price of plating used to be mostly polishing.
    Most people don't know that, when chtome plating, the piece is polished and buffed do that it looks like it's chromed before it even goes in the tank.
    Now I suppose there's more money involved in pleasing the EPA.
  6. Drak
    Drak Tele-Holic
    DC 'Burbs
    Most gold platers will shoot a thin layer of lacquer over top before they hand it back to you because the gold plating is so thin.
    And they will go out of their way to make sure you know that so you don't use metal polishers on the piece(s) and destroy the thin lacquer coating on top.
    For the past many years, I just use my airbrush and mix up a tinted lacquer concoction that simulates gold as close as I can get it.
    Works for me and costs me nothing, I already have all those supplies here.
  7. jvin248
    jvin248 Doctor of Teleocity
    Lions & Tigers oh Mi !
    Look up watch repair and gold plating to get an idea of what is involved.
  8. RolandG
    RolandG Tele-Meister
    Gold is a soft metal. Playing will wear off quickly. If you really want gold coloured frets then re-fret with EVO GOLD fret wire. It’s not quite as hard as stainless steel but not noticeably over then playing life of a guitar.
  9. Ripthorn
    Ripthorn Friend of Leo's
    Austin, TX
    If you go to Caswell and look at gold plating, it costs about $250 for a small bottle of gold plating solution. But wait, there's more! For stainless you have to have a stainless activator and then I think an acid copper, so you are looking at a minimum $300 to plate it yourself, not to mention all the trial and error (which involves obscene amounts of cleaning) and then you end up with a very fragile plating. Most gold plated guitar hardware is not actual gold plating, but a mixture of materials to give it a gold appearance and wear a little better, but you can't just go out and buy that solution.
  10. kennl
    kennl Tele-Afflicted
    Moon Township, PA
    check the stainless steel parts with a magnet
    some SS alloys are non-magnetic
    I don't think electroplating those will be possible
  11. old wrench
    Here's a question for you @gb Custom Shop -
    What difference would it make if the part under the gold plating was stainless or regular carbon steel?
    There is very little basic difference between the two other than the stainless alloy has a high chrome content which deters staining and rusting, which is sort of a moot point once they are gold plated.
