Converting Harley Benton Mighty 15 to 115v
  • Thread starter LAPickGuitar
LAPickGuitar
Birmingham, AL, United States
A couple years ago I wanted to buy a cheap LP copy so I could have a humbucker setup. When I saw the HB 15 watt tube amp for ~$200 (great exchange rate then) i threw it in to the order, even though it was 230v only (I already had the step-down power supply). It's actually a pretty good amp for how I use it. But as I've learned about tube amps here and elsewhere, I decided to investigate whether I could easily change mine to 115v. Yes, I could.
I don't post it here because it's some great breakthrough, but because it took me a while to get the details, so maybe this will save someone else the effort.
Black and red were just connected with a wire nut, so disconnected that. White was just a capped wire, so I tied the white and black with the same wire nut. I made a Y connector for the Faston on the yellow wire to tie in the red so it would be easy to reverse.
Starting point:
Mod, before I taped the wire nut and zip tied:
Fuse was a 315mA, replaced with a .630mA - 5mm x 20mm
2L man
Finland
I just noticed that in the schematic I copped from a similar Laney amp, the fuse is shown on the supply side of the switch (bad idea), it's on the device side of the switch in the HB.
It does not have much effect. Most countries the mains voltage is 2x higher and still the plug does not have "polarity" so 50% of times they are connect the fuse is in Neutral.
Primary fuse prevent primary wiring insulation melt and possibly catch fire. Also when primary fuse burn power transformer does not come hot although it is which was already failed.
printer2
All true. The 'bad idea' part is that removing the fuse with it plugged in (also a bad idea) is a shock risk.
The fuse holder cap holds the fuse. As you twist the fuse holder cap the fuse is removed with the cap. How is it a shock hazard?
