convert off-on-off Gibson pickup selector to on-off-on Dano pickup selector
Discussion in 'Tele Home Depot' started by papaschtroumpf, Oct 29, 2020.
  1. papaschtroumpf
    papaschtroumpf Tele-Holic
    Colorado
    I could have sworn I had seen instructions on how to take a gibson style switch and rearrange the leaves to turn it into an on-off-on switch so I could wire pickups in series Danelectro style
    Any idea? If all else fails I'll buy a switch but I like the idea of modifying the spare I have lying around
    crazydave911 likes this.
  2. wabashslim
    wabashslim Tele-Afflicted
    Sonorous Desert
    I got curious how these Danos were wired since I used to have a 59 12-string. Pretty clever way to cheap out on parts. Anyway I don't know about rearranging the Gibson switch - and I wouldn't - but you should be able to figure it out by staring at it for awhile.
    Besides, on-off-on switches are easy to find in many styles...more than the on-on-on toggles guitars normally use.
  3. Freeman Keller
    The normal wiring for a Gibson is one pickup/both/the other (Neck/both/bridge). If you look at your picture, there are two groups of two terminals on the right side. If you bend the inner ones together that becomes the output, the out side terminals become the two inputs. Is is the usual LP wiring, there are lots of variations. This puts the pickups in parallel in the middle position
    Don't have any idea how a Danoelectric works thats how a Gibbie does it.
  4. wabashslim
    Sonorous Desert
    Danos, at least the kind he wants, are both pickups in series in the middle position. The switch is garden variety on-off-on toggle, not like a Gibson at all.
    crazydave911 and SecretSquirrel like this.
  5. papaschtroumpf
    Colorado
    that's the point. I heard you can rearrange the internal blades of a Gibson switch to make it on-off-on, instead of buying a new switch, which I can't find cheap with a tip/lever style I like. they are either too thin or industrial size and hard to operate.
  6. wabashslim
    Sonorous Desert
    The switch pictured is the cheapo import version, I don't know if it successfully comes apart & goes back together, but the US version might. Like I said, I'll bet if you just study it awhile you can figure it out.
  7. Peegoo
    Peegoo Poster Extraordinaire
    Wyoming panhandle
    It does; the two little screws run through a sandwich of conductors and insulators into a threaded plate on the opposits side.
  8. E-miel
    E-miel Tele-Meister
    Drenthe, Netherlands
    I did that once. But that's a few years ago. I remember it was quite fiddly. The plates need just the right amount of bend to keep the handle from being able to move in the middle position. I'll have a look if I can find it in my parts collection.
  9. peterg
    peterg TDPRI Member
    Toronto
    Here is the order to rebuild the switch to have on-off-on switching. The phenolic paper (or whatever the insulation pieces in your switch are made from) go back between the metal pieces. The wiring tabs on the middle pieces (the ones with the hoop and connect with the post) need to be bent together.
    SecretSquirrel and crazydave911 like this.
