Conundrum: Perfect neck but heavy(ish) guitar
gitold
Greeley Co.
Better strap? I don’t care what my guitars or basses weigh, never have weighed one. But everyone has different preferences. If you like the neck, that’s the most important thing to me. It’s also the one thing that’s hard to change.
Try out different size straps. Wide suede straps can make a heavy guitar more comfy for sure.
teletina
dubrovnik
TeleBackelaer
The Netherlands
Plot twist - I got a kitchen scale and weighed it. Lo and behold... 7lbs 9oz, or 7.6 lbs. So, call me weak and feeble cause that shouldn't be too heavy. It's no featherweight but quite reasonable. Must just be the way it hangs or something? In fact, it's the lightest Tele I own. Turns out the 'ole trusty Highway 1 I've played for 15 years is 7.75lbs. Must be a perspective issue because the guitar I sold to buy this one was a 7 pounder (but I didn't like the neck). Maybe once you've had a sampling of a 7 pounder you don't ever forget it?
Weird isn't it? For ages I was absolutely, 100% sure my main tele was heavier than my strat. Then finally I decided to weigh 'em: turns out they weigh exactly the same. Numbers don't lie, but my tele still feels heavier than the strat 😄
Anyway, if you love the way it sounds, I'd definitely keep it as is. And yeah, 7.6 isn't all that heavy imo. I think chances are you'll get used to it.
Catsandstrats
It is weird! My favorite Strat is right under 8lbs (listed as 8lbs from the retailer, 7lb 15oz on my kitchen scale) and I was convinced this Tele was at least as much or a bit heavier. Totally strange. The best I can think is that the weight distribution is different between the body shapes and the location of the tremolo block.
2HBStrat
Four Rivers Area of Middle America
Here’s a conundrum - I bought a used CS 1960 Tele a few weeks back. The neck is perfect but the guitar is a bit heavy.
Seemed normal in the store but as I’ve lived with it the weight is starting to annoy me a bit. I don’t know the weight measurement, this all based on shoulder feel.
Do I enjoy the perfect neck and get over the weight or move it along and hope I find something lighter with as good of a neck? Decisions decisions. What say the folks here?
I would probably keep the guitar as is but in the meantime start looking for another guitar, similar to it with a neck I liked just as much, to trade it for. If it wasn't a Custom Shop Fender I would probably try to trade bodies.
jchabalk
Northern California
I had a similar problem with the balance of my tele (partscaster). Here are some observations i made while building up another which my be useful to this discussion (link).
The key thing is the balance was the primary issue rather than the overall weight - and neck dive is a bummer. There's a neck:body ratio which seems to help a lot (as a target).
arlum
Platinum Supporter
O'Fallon, MO
Body weights are easy to find. Perfect necks are not. If I could have one or the other the neck would trump the body every single time. I'd play, (and never trade in), a guitar with a perfect neck for long and long. No matter the other issues .... perfect necks are #1 in my book. Unless you can find a lighter bodied guitar with a neck that equals or exceeds what you already own I wouldn't consider a replacement purchase. I'm 68. Weight is an issue. I'd bow my back if that's what it took to own the perfect neck.
Catsandstrats
Off-topic from the weight question but man, I love that ”tru-grain” finish on your Tele. I’ve been dreaming of assembling a Tele or Strat from Guitar Mill parts and this isn’t helping 😂
TelePlank
I usually buy guitars in the 7.5 or 7.6 pound range. I have an Esquire that's 6 pounds and like 14 ounces or so. My latest buy is 7.9 pounds so the heaviest I own currently. I don't think about it when I pick it up, but if I play it right after another I feel it. Not a problem honestly and I guess I'll live by: As long as it's under eight it's great!
tomasz
Europe
Since you know, what you like in that guitar, keep looking, but don't move it until you find one that ticks more boxes. Btw, it could also be a loooong hunt
TokyoPortrait
Tokyo, Japan
Hi.
Dunno. You’re already thinking of selling it. If you’re not happy, you’re not happy.
Flip side, give it some time, try different strap positions and / or straps, etc, and it may turn into a non issue.
You have other Teles, I think. You could try swapping the necks, and see how things feel? Not sure how that would help, but if your other one ‘feels’ lighter, you may end up happy.
Yeah, pretty sure this is a thing. I was the same with my two Teles. Then I weighed them. Both exactly 3.4 kg (aka 7.49 lb).
Pax/
Dean
Matthias
Third rock from the Sun
You might need to audition a few to get under 7.6lb and it might be hard to find the body you want at the right weight if you replace that. Get a 2.5” or even 3” strap and avoid the webbing ones. It makes a huge difference.
KeithDavies 100
Cambridge, UK
I was going to suggest a wider, or more padded, strap, but several others got there before me.
I'm also with some others though that suggest that if it's already entering your head to sell it, then perhaps that's the way to go. My own experience that when that thought enters my head, it's almost always just a matter of time, as I struggle with the idea. (That said, my main guitar of the last 35 years now almost got traded in about 6 months after I bought it, so you never know!)
Blues Twanger
SoVT
You might never find another with a neck that feels like that one. A good guitar is more than it's specs. For me the neck feel is usually the most important attribute, I own guitars I would've otherwise passed on just looking at specs because of how the neck feels. I've sold amazing guitars that ticked all the other boxes because the necks were not what I wanted.
