Control Plate for Tele w/1 Hole?
Discussion in 'Telecaster Discussion Forum' started by guitarist232345, Oct 18, 2020.
  1. guitarist232345
    guitarist232345 Tele-Meister
    Venus
    Hi guys,
    I am looking for a Tele control plate with one hole next to the switch. The idea is to have one knob next to the switch and to then flip the plate so that there is more space for my picking hand to flair out when playing and so my fingers don't hit either a knob or a switch.
    Does anyone know where I can find a Tele control plate with one hole for a knob [instead of 2] with a switch in the UK?
  2. 440mhz
    440mhz Tele-Meister
    Englehart, On, Canada
    GFS has blank control plates, just drill the holes where you want to.
    SPUDCASTER, Peegoo and casey2910 like this.
  3. guitarist232345
    Venus
    Unfortunately I live in a small inner-city flat, so this is not an option at all.
  4. REWTX
    REWTX Tele-Meister
    DFW
    Rockrabbitguitars.com
    Telecentric, El Tele Lobo and drf64 like this.
  5. drf64
    drf64 Poster Extraordinaire
    Ada, MI
    wow. who knew? but doe this help? I'm thinking you want the hole next to the switch with space at the end?
    mkdaws32 and casey2910 like this.
  6. casey2910
    casey2910 Tele-Meister
    arkansas
    Volume up front and switch to the back!
  7. blue metalflake
    blue metalflake Doctor of Teleocity
    ireland
    You could look at axesrus & all parts UK sites. Probably your best chance in UK
  8. stepvan
    stepvan Tele-Holic Silver Supporter
    out there somewhere
    Surely you must know someone who could drill one hole in it for you
    guitarist232345 likes this.
  9. Telecentric
    Telecentric Tele-Holic
    Boulder Creek, Ca
    Not a lot of machine shops on Venus, or so I hear.
    +1 on rockrabbit. I ended up making my own from GFS blank
    guitarist232345 and stepvan like this.
  10. guitarist232345
    Venus
    Thanks for finding this but yes, I would like the space at the end
  11. guitarist232345
    Venus
    Unfortunately no
  12. Peegoo
    Peegoo Poster Extraordinaire
    Between the Raindrops
    The Guitar Hospital (London)
    The Guitar Repair Workshop (Liverpool)
    These two places can easily make you what you want. It shouldn't be expensive at all because a blank (undrilled) plate is a few pounds.
    Give 'em a call, let 'em know what you need, and they should be able to bang one out in a day or two. Have your requirements written down, e.g., "8mm diameter hole for a single control pot centered 40mm from one end of the plate, with no switch slot or other holes," etc., because they will ask for specifics.
    I've done similar stuff on my own builds. This one has a volume and a tone. No switch because only one pickup:
    matty428 likes this.
  13. loopfinding
    loopfinding Tele-Afflicted
    europe endless
    Ugh how dare you not “work the tone,” you must be a horrible guitarist!
    anyway, I live in a small flat as well. If you can do it in the daytime with a cheap cordless drill and a stepper bit, you should be able to get away with it. You just have to clamp it to your desk or something. Or maybe do it outside by the garbage bins.
  14. Peegoo
    A really simple way to hold a blank plate (they already have the little screw hole on each end) is to use those screws to affix it directly to a scrap of wood about a foot long. Drill through the plate and into the wood.
  15. Ghostdriver
    Ghostdriver Tele-Meister Silver Supporter
    England
    I am in the UK, I build a lot of Teles, I always buy blank control plates in chrome and drill myself, listen, if you want one I will sort it for you and drill it where you require it, ping me a message and maybe we can sort something.
