Connection from Piezo to Preamp
Discussion in 'Acoustic Heaven' started by Bandihoop, May 28, 2020.
  1. Bandihoop
    Bandihoop TDPRI Member
    Brisbane, Australia
    Hi, I have a Cort acoustic guitar with a CE304T preamp. The preamp has died and I was able to get a replacement from Cort. Unfortunately as you can see in the photo below the piezo was directly soldered to the original preamp (green) where as the replacement one (blue) has some kind of connector. Is anyone familiar with this connection type? I'll need to get a male connector to wire the piezo to.
  2. Bandihoop
    Brisbane, Australia
  3. mortron
    mortron TDPRI Member
    It looks like a 3.5mm socket like a headphone jack... But cAnt be certain. You would just have to terminate the peizo with the appropriate 3.5mm (if that's what it is) connector.
    I would contact Cort for confirmation, they may even send you a connector... Maybe they do this now to facilitate easier assembly, service and the ability to swap pickups?
    Bandihoop likes this.
  4. Bandihoop
    Brisbane, Australia
    Thanks mortron. I'll reach out to Cort. I just check and my 3.5mm headphone jack doesn't fit it. But maybe it's a smaller version (2.5mm?).
  5. Bandihoop
    Brisbane, Australia
  6. tdoty
    tdoty Tele-Meister
    Winchester, Tennessee
    My preamp has a 2.5mm jack. I don't know how much that helps you though.
  7. navigate40
    navigate40 Tele-Meister
    SE FL
    It is probably 2.5mm. There are several after market piezo elements that you can get that have these types of connectors.
    One thing...you might find some Shadow ones....I *think* they do this. They may not be compatible, however, because of their impedance.
    There should be plenty of generic ones.
    Hope this helps.
    [also....you could actually clip the piezo from your old unit, solder it into a 2.5mm plug and use that]
