Confusion, Which Fret to Measure Initial Height of String Action
Discussion in 'Tele-Technical' started by Digiplay, Mar 23, 2020.
  1. Digiplay
    Digiplay Tele-Meister
    Birmingham, Alabama
    I'm setting up my new saddle's/action height, and I have two conflicting instruction's on which fret to measure the action from.
    Sweetwater says:
    Place the ruler on the 12th fret, making sure the ruler ticks are parallel to the string.
    Do this so that you’re getting an accurate measurement of the gap from the top of the fret to the bottom of the string.
    Fender says:
    Measure the distance between bottom of strings and top of the 17th fret.
    So which fret should I measure from?
  2. Jakedog
    The North Coast
    Man I have no idea. I’ve been setting up guitars for decades and I’ve never measured the action. I do it all by eye and feel, and how the player wants it.
    Same goes for relief, nut height, pickup height, all of it.
  3. koolaide
    koolaide Tele-Holic
    south carolina
    I would go with Fender. They are the mfg.
    daddyplaysbass likes this.
  4. trev333
    Coolum Beach,Australia
    about here for mine....;)
  5. Digiplay
    Birmingham, Alabama
    What is it under the E string that appears to be allowing the height you like?
  6. adamgdog
    adamgdog Tele-Meister
    Louisville
    Looks like the head of a match stick to me
    Sent from my SM-G973U1 using Tapatalk
    Jakedog and trev333 like this.
  7. Digiplay
    Birmingham, Alabama
    I'm envious of you Jakedog :)
    Jakedog likes this.
  8. Digiplay
    Birmingham, Alabama
    If so, that sure is some potentially HOT action!!!!!!!!!!
    Thank you very much, all of you are a GREAT audience :) :) :) :) :) :) :) :)
  9. tah1962
    tah1962 Tele-Afflicted
    Heart of Illinois
    I use a StewMac string action gauge. It’s around 4” long so I put one end on the 12th fret which basically covers the 12th to 15th fret.
  10. Ess Eff
    Ess Eff Tele-Holic
    Yup, doesn't really matter as long as you are consistent.
    12, 17, 21.... Just measure what feels right at any fret and do the same everytime.
    I use 12 and a 1.5mm allen key. Then usually tweak it a bit more anyway.
    JK202 and LutherBurger like this.
  11. Bill Sheehan
    Bill Sheehan Tele-Meister
    Central Illinois
    Jakedog likes this.
  12. trev333
    I found that out one day when looking for a basic gauge to check my tele guitars for the average action I'd set on most of them .... just happened to be a box of redheads on the table, I tried one and it was just right to use for a quick check instead of fumbling around with anything scientific to measure with..
    the proof is in the playing.... I don't shoot for the absolute lowest I could go... everyone has a different feel they like/use .... too low and your finger tips drag too much wood....
    Keep on Truckin and Bill Sheehan like this.
  13. dreamingtele
    dreamingtele Friend of Leo's
    Melbourne, Australia
    I've been setting my action from the 12th fret string..
    I have all my guitars set up with the same action, but Ive had my frets dead level and nut correctly cut for 11's.. so that helps..
  14. slauson slim
    slauson slim Friend of Leo's
    By The Levee
    I begin with the Fender recommendation and tweak a bit from there, also for pickup height and neck relief. I know there are a myriad of systems and methods.
    I used to use Hideo Kamimoto's book Complete Guitar Repair as a guide. Lots of good info.
    The Stew-Mac gauge is a useful tool
  15. trev333
    I do have a CC sized tool that came with something I bought, if I need to know actual numbers this works ok... just lay it on the frets on edge and look side on to see which one lines up ... works as a quick fret rocker too..;)
    SnidelyWhiplash and Jakedog like this.
  16. Bill Sheehan
    Central Illinois
    Digiplay, for what it's worth, I've always had good luck with my "quarter's worth of action" method:
    Take a quarter and slide it under the 6th and 5th strings, letting it sit on top of the sixteenth and seventeenth frets (similar to a bridge span over a body of water). Start out with the string action deliberately higher than you ultimately want it to be. Then, slowly lower the height of each string just to the point where it BARELY starts making contact with the top of the quarter, such that it creates sort of a "sitar" sound when you lightly pick the open string.
    Then, do the same procedure with the quarter positioned beneath the 4th and 3rd strings; and then likewise with the quarter positioned beneath the 2nd and 1st strings.
    When you're done, you'll have a nice medium-low action, and the strings will nicely follow the radius of your fret board. It's a good starting point, and from there you can lower the strings a bit more if they seem too high, or raise the strings a bit if you're feeling too close to the "buzz threshold".
    (This may be no match for Trev's method, I admit...) ;)
    JK202 and trev333 like this.
  17. medownsouth
    medownsouth Tele-Meister
    Tremont, MS
    This is what I use too.
    12th fret 1/16 to 5/64 low/high. Use a radius guage to set saddles & feeler guage to set neck relief
  18. medownsouth
    Tremont, MS
    Watch these 4, you’ll be set
    JK202 likes this.
  19. Digiplay
    Birmingham, Alabama
    Hi tah1962!
    I have a FretGuru2, and it's about 3 1/2" long.
    Regardless, it seems like neither Fender or Sweetwater is definitively correct :)
    Thanks Bill!
    BTW, do you know who it is that made me say my joke?
    It was SATAN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Thanks again,
    Jerry
    tah1962 likes this.
  20. Bill Sheehan
    Central Illinois
    Hahahahahahaha!! Love it!!
    tah1962 likes this.
