concentric knobs for cts dual pots
Discussion in 'Tele Home Depot' started by old_picker, Aug 31, 2020.
  1. old_picker
    old_picker Tele-Afflicted
    Melbourne Australia
    Any body got a tip as to where I can get these?
    Concentric knobs for CTS 500k/500k dual concentric "stacked" audio taper pot
    Top shaft is 3/16"(4.75mm) diameter
    bottom shaft is 17/64"(6.75mm) diameter.
    There are plenty out there but none I can locate atm with correct shaft sizes.
    These are a vintage '62 jazz bass set - I use the chrome units instead of the vintage correct ones with black lower knob and chrome upper knob.
    Allparts are out so are Guitar Parts resource - have the pots and some mini concentric knobs which are wrong size
    euro zone or USA is fine
    thanks
  2. Guitarteach
  3. tubegeek
    tubegeek Friend of Leo's
    Brooklyn, NY
    Small Bear is a great retailer that focuses mostly on parts for making pedals - they have a few choices of concentric pots & knobs. Also Tayda Electronics.
    http://smallbear-electronics.mybigcommerce.com/
    I've also seen them in auto parts stores as replacements for the radio's knobs.
  4. old_picker
    Melbourne Australia
    Alas neither have of concentric knobs to fit the CTS dual gang pots
    I believe these were used oreiginally on the '62 Jazz bass - the mini's are physically too small I reckon.
    anyone else got a tip?
  5. old_picker
    Melbourne Australia
    unfortunately no - wrong shaft sizes 8mm and 6mm
    The Knobs I'm after are essentially '62 jazz bass stack knobs - the ones I prefer have chrome top and bottom where the originals have a black lower knob.
  6. kingofdogs1950
    kingofdogs1950 Tele-Afflicted
    Franklin, Texas
    Might be easier to change to a different dual pot that uses the available knobs.
    M
  7. TwangToInfinity
    TwangToInfinity Tele-Afflicted
    Twangville
  8. old_picker
    Melbourne Australia
    the mini's are way too small and fiddly - has to be the bigger ones - just easier to operate - there's millions of those tiny little concentric knobs available - they look like toy knobs :)
  9. TwangToInfinity
    Twangville
    oh yea i see that now, whoops, i wonder where the heck i got mine from?
    i guess it was quite awhile ago sry about that
  10. stale facet
    stale facet TDPRI Member Silver Supporter
    Massachusetts
    Did you ever find the knobs you were looking for?
    These Warmoth knobs look like the right sizes:
    https://www.warmoth.com/Concentric-Pot-C825.aspx
    lower:
    • 3/8" (9.5 mm) High, 11/16" (17.5 mm) Wide.
    • Fits on a 17/64" (6.75 mm) shaft.
    Upper:
    • 1/2" (12.7 mm) High, 9/16" (14.3 mm) Wide.
    • Fits on a 3/16" (4.76 mm) shaft.
    vintage and modern styles, chrome, black or gold.
    Ran into the same problem here finding these recently. Hope it helps you or someone else in the future.
  11. old_picker
    Melbourne Australia
    yeah they eventually come through the local allparts distributor up here in Oz
    stale facet likes this.
