Compressor with gain
Discussion in 'The Stomp Box' started by golfnut, Aug 4, 2019.
  1. golfnut
    golfnut Friend of Leo's
    Are there many compressors with a gain knob for adding a bit of grit\dirt? List them here.
  2. Paul in Colorado
    R.I.P. 2019
    Most all of them have some kind of level control, but I don't know any that have a knob to create any kind of distortion or overdrive. That's not a compressor's job.
    artdecade, dodona, marcflores and 2 others like this.
  3. golfnut
  4. telemnemonics
    Pigtronix philosophers tone comps have a grit switch as well as gain that isn't dirty.
    Also they have a knob to add back some attack to keep some original dynamics while adding more to the decay.
    I have the bass version and the grit switch is not subtle.
    Might not be what you're looking for.
    The Rt66 by puretone or visual sound has a pretty good comp on one side and a very nice version of a TS808 on the other side.
    You can run both and the lowest setting of that 808 circuit is an excellent clean boost, so you can add more subtle grit there.
    It also has a bass boost switch and a tone knob allowing treble and bass boost for less mid hump, should you prefer.
  5. Obsessed
    Montana
    This is your answer. The best compressor I have used and you can add some grit with the Drive pot. Only recommended for experienced compressor pedal users IMHO. IMG_4045.JPG
    sanfi4u and richiek65 like this.
  6. Archtop Bill
    Archtop Bill Tele-Meister
    Asheville, The Paris of the South
  7. lineboat
    lineboat Friend of Leo's
    Analog Alien has one. It works and it’s yellow. That’s all I remember about it.
    Archtop Bill likes this.
  8. cm3ohana
    cm3ohana TDPRI Member
    California
    JHS Pulp N Peel v4 has a grit toggle switch and a small trim pot to adjust the amount of grit in the mix.
  9. wrathfuldeity
    wrathfuldeity Tele-Afflicted
    Turdcaster, WA
    I support via ime...the vfe white horse...and I'm a compressor noob.
    Obsessed likes this.
  10. Tonetele
    South Australia
    Boss make a great compressor which has great sustain.
  11. rze99
    rze99 Poster Extraordinaire
    South London UK
    Interesting I thought this was just a clean optical comp. Where is the drive pot? I don’t see it.
  12. FMA
    FMA Poster Extraordinaire
    As someone mentioned, the Philosopher's Tone has a grit knob. I usually keep it turned down all the way. I'm not crazy about how it sounds. The PT, though, has some very useful features for me, anyway. The blend knob allows you to mix dry signal with compressed, the result being that you can keep your attack intact. And it has a treble knob that allows you to keep your top end present and, as a side benefit, works well at getting that nice jangly thing happening.
  13. Obsessed
    Montana
    Top dead center. It is a black splined post sticking out. I assume so you don't accidentally bump it, but it works really well on top of a very quiet optical compressor. I had borrowed three compressors from a good buddy while he was in recording mode and learn as much as I could spending most of those two years on the Empress. I think you really need to understand all of the compression attributes, before using the White Horse. Otherwise, I think it would be easy to get lost. The gain is really something to behold, but as good compressors go, this is fairly subtle, so don't expect a RAT-in-a-compressor box.
  14. twangjeff
    twangjeff Tele-Afflicted
    Houston, TX
    The Philosopher's Tone is a way underrated pedal IMO. You can find them used on the cheap now, it may be just what you're looking for.
  15. Obsessed
    Montana
    Oh, BTW, the "Response" and "Bass" on the White Horse use similar black posts. You should be able to see the line indicator on the top of these posts in the pic.
    rze99 likes this.
  16. KC
    KC Friend of Leo's
    Missoula, Montana
    Cali76 Compact has input & output level controls. I use the output to drive the amp & use the input to control the amulet of compression. Takes a while to learn to drive it but this thing gives a nice kick to the front end of the amp. The way I use it, it's not a subtle effect -- light compression & a fair amount of clean boost. Any dirt comes from the amp, not the pedal.
    MrGibbly and Wallace Snr like this.
  17. MilwMark
    near Arnold's
    Durham SexDrive
  18. MilwMark
    near Arnold's
    Also, if the OP specifically wants a comp with a dirt knob, why do so many feel the need to post their favorite comp that lacks that function?
  19. WildcatTele
    WildcatTele Tele-Meister
    McPherson, KS
    My plain ol' Dynacomp is unity gain at about 2 or 3 oclock, adds enough after that to push my Blues DeVille very nicely.
  20. MilwMark
    near Arnold's
    The OP wants a comp with a drive knob (or maybe toggle). Why is that so hard to understand?
    Every comp with enough level will drive an amp harder but that’s not what was asked.
