Compressor revisited, suggestions please
Discussion in 'The Stomp Box' started by MrHamburger, Oct 15, 2018.
  1. Charlie Bernstein
    Augusta, Maine
    My experience exactly. See my post above. Comps made everything sound denatured, liveless, and, in a word, terrible.
    But then I discovered that using a comp that has a blend control lets me keep my dynamics while adding sustain. Bizarre, I know, but it really works.
    4pickupguy and telemnemonics like this.
  2. Charlie Bernstein
    Augusta, Maine
    Yes! Exactly what I've been saying above. Always hated what comp did until I got a Philosopher's Tone. It gives me buckets of sustain without sucking any of the life out of the guitar sound.
    I'm more of a neck and middle guy, but I've had exactly the same experience as you.
    telemnemonics likes this.
  3. MilwMark
    near Arnold's
    Not my experience but glad it works for you.
    Charlie Bernstein likes this.
  4. midnight340
    midnight340 Tele-Meister
    Lawrence, KS
    Using blend control at half and keeping the sustain/ compression relatively low the Tone Corset does subtle but magical things for my Gretsch Power Jet.
    Haven’t felt the need to try it much yet with either the Tele or Jazzmaster.
    bgmacaw likes this.
  5. richey88
    richey88 Friend of Leo's
    philly suburbs
    So I have a multi effect (Sonicake, not a lot on these online) has a comp that sounds great when you need a little boost to your clean tone. Very happy with this lil gem. Twiggy Blues it’s called. Not good experience with Dyna Comp, had DOD like above here, liked that but am about downsizing these days
  6. FenderLover
    FenderLover Friend of Leo's
    Minnesota
    Every Compressor thread (revisited):
    - Every comp has now been recommended, again....
    - I would never use a compressor
    - My compressor is always on
    - Comps suck, and here's why....
    - Comps are great, and here's why....
    AngelStrummer, scout2112 and MilwMark like this.
  7. NWinther
    NWinther Tele-Afflicted
    Denmark Solbjerg.
    About right.....
    Or the blend is best thing ever since cats got paws!
    MilwMark and FenderLover like this.
  8. Middleman
    Middleman Friend of Leo's
    MV, CA
    For direct line recording, country music mind you, the Keeley Compressor Plus followed by the Exotic EP Boost is pretty hard to beat. You can control the wet dry and it's the closest pedal I've found that can rival an actual 1176 studio compressor.
    Live however, unless it's for some special effect, I wouldn't use one.
    Tele56 likes this.
  9. MrHamburger
    MrHamburger Tele-Holic
    Portlandia
    So far I’m leaning toward the dod280 hoping it is similarly voiced to the fx80b & milkbox.
  10. bluebirdrad
    bluebirdrad Tele-Meister
    St Augustine, Fl
    I have never liked compressors either, especially the Dynacomp/Ross/Keeley types but the new ones with the blend control changed the game for me (best thing since cats got paws!) I am very happy with the Xotic SP compressor. I tried it out next to the Wampler Ego. Don't let the small size and 2 knobs deceive you. It is brilliantly designed to do it's job with minimum tweaking. You can go from subliminal compression to full squash with the blend knob and the toggle switch. It is a Ross type compressor so basically sounds like the Keeley, Wampler, the other Ross derivatives. Not an optical compressor if that's what you're looking for.
  11. NashvilleDeluxe
    NashvilleDeluxe Tele-Holic
    West Island, Quebec
    TC Electronics' Hypergravity is a contender...the 4 knob full-sized, not the mini.
    In addition to the attack, sustain, level and blend knobs, you have the "vintage" and "spectra" modes, and most important, the TonePrint for importing settings from some long-time users of compression.
    This demo is my style...no endless banter...just playing.
  12. moosie
    Western Connecticut
    Definitely a polarizing topic. :lol: And a much harder effect to use properly compared to overdrive, delay, etc.
  13. Charlie Bernstein
    Augusta, Maine
    And just a guess based on your Rat avatar is that you drive your amp hard enough that it's already squashing nicely without sticking a cherry on top.
    Pete Townsend says that even though he uses a compressor, it's just because it's there. His sound is already about as compressed as it can get without it.
  14. MilwMark
    near Arnold's
    I just love how the Rat looks. I use one at home set subtly to give some overdrive. But not live. To me a compressor pedal and how an amp (or good OD) compresses fee and sound quite different. Live I don’t have any “always on” pedals and my overdrive is only for leads, with just enough EQ shift and level increase to lift enough to stand out a bit.
  15. Strebs
    Strebs Tele-Meister
    Michigan
    The Monoprice compressor is only $20 bucks right now and gets good reviews. For 20 bones, it may be worth a try.
  16. Redheadlvr
    Redheadlvr TDPRI Member
    Greer,SC
    Wow...lots of differing comments.
    As far as comps are concerned I use rackmounts-Bellari RP282 and a Behringer T1952,both tube
  17. HWTele
    HWTele Tele-Holic
    BetweenHere&There
    I use an inexpensive BBE Vari-comp ....don’t use a compressor often but this gets the job done.
  18. luckett
    luckett Banned
    Compressor threads aren't complete until someone claims that the Mooer yellow comp is a clone of the Diamond comp because they are both yellow.
    MilwMark likes this.
  19. bgmacaw
    bgmacaw Friend of Leo's
    Near Athens GA USA
    It's an optical comp, similar to the Ammoon I mentioned earlier. It should work well as a boost and mild comp. It won't get the super squishy tones though.
    Strebs likes this.
  20. GuitarJonz
    GuitarJonz Poster Extraordinaire
    MA
    Yes, that one sounded good to me too, in the 2 videos above. I've never used compressors, but would like to try one of those.
