Compressor Help!
Discussion in 'Worship Service Players' started by will91, Mar 12, 2017.
  1. will91
    will91 TDPRI Member
    Sydney, Australia
    Hey guys, hoping to get some quick advice. I am on the verge of adding a compressor to my board. I am looking for something to work in an always on capacity to help even things out, add sustain and all round lift my tone. I have narrowed my search down to three all in my price range -
    Xotic SP
    Pigtronics Philosophers Tone (Micro)
    TC Hyper Gravity
    Would appreciate any comments or experience. I mainly play worship in the Hillsong, Crowder, Passion vein.
    Current rig is: Tele - Tuner - JHS Morning Glory - Ib TS9 - Volume - Boss DD7 - EQD Dispatch Master - Boss TR2 - Strymon BlueSky - Amp
  2. blille
    blille Tele-Afflicted
    Bay Area - California, USA
    For a subtle always on I personally gravitate towards optical. The pigtronix is the only one you have but afaik it might not be the easiest to dial in. Of the three you have I would go with the Xotic but I would encourage you to consider other optical compressors with low comp ratios (e.g. 4:1). I use a Maxon CP101 but there are many others, the Diamond being likely the most notable example. If you want small and cheap, Mooer's yellow comp is a clone.
    If you haven't seen this yet, this is the best resource for comp reviews: http://www.ovnilab.com/
  3. will91
    will91 TDPRI Member
    Sydney, Australia
    Thanks man, appreciate the tip. I seem to be leaning towards the Pigtronix and it has the blend know like the SP to ensure I can dial in something subtle enough not to get in the way. Jumping on Ovnilab now.
    blille likes this.
  4. mRtINY
    mRtINY Tele-Afflicted
    Orygun
    That one has parallel compression, I think... It should, mostly, bring up the low levels.
  5. CapnCrunch
    CapnCrunch Friend of Leo's
    Washington, USA
    When I decided to put a compressor on my board, I played a bunch of them. Several Ross types, Diamond, Strymon, and Empress. The Empress was the winner for me. I Can't recommend it highly enough.
  6. jvanginkel
    jvanginkel TDPRI Member
    Mission Viejo, CA
    The blend option is a necessity for me with an "always on" compressor. I use a Ross type with a blend control and I feel like I can still play dynamically, without everything being squashed or lifted.
  7. Dardeau
    Dardeau TDPRI Member
    New Orleans
    I use a Ross type with a blend as well. I actually just bought one of the new mini Dyna Comps to stack with the Ross type Lowell George style for slide. They are really cool, but without the blend probably not good for always on. The SP has size and a blend knob going for it.
    jvanginkel likes this.
  8. CAAD8N8
    CAAD8N8 Tele-Holic
    Ohio
    I love the tc hypergravity. Love the flexibility and blend knob
  9. Tele-beeb
    Tele-beeb Friend of Leo's
    The Bluegrass
    I have had so many compressors I can't remember.
    I kept hoping I'd get results others got.
    The only one quiet enough and made an improvement is the
    SP!
  10. telepraise
    telepraise Tele-Holic
    Tampa Bay
    Might be a little above the range your considering, but I'm very pleased with the Wampler Ego. It allows you add a little sparkle and body to your tone. You really miss it when you turn it off. Very transparent in the clean tones which is important to me.
