Compressor, do I need one?
Discussion in 'The Stomp Box' started by vanr, May 26, 2019.
  1. El Marin
    El Marin Tele-Afflicted
    Madrid, Spain, EU
    I did that. Using a CS3 as a booster. Worst idea ever
    Now I hate compresors
  2. MilwMark
    near Arnold's
    Normally clean sounds sit in a mix better than saturated sounds.
    Unless your clean sound is so squeaky clean that the amp isn't compressing at all.
    I'd figure out what is going on with your clean and dirty tone before adding a compressor.
    Compressors exist to compress. Don't get one if you don't want compression. Look to the root cause.
  3. DuckDodgers
    DuckDodgers Tele-Meister Silver Supporter
    Dee-troit City
    I have a Mooer Pure Boost pedal that does what you’re looking for even better than the compressors I’ve used, and it was dirt cheap.
    igor5 and TokyoPortrait like this.
  4. cyclopean
    cyclopean Poster Extraordinaire
    innsmouth, MA
    why give up anything?
  5. RetroTeleRod
    RetroTeleRod Poster Extraordinaire
    Oklahoma, USA
    I own four compressors that I don't use. Instead I like a overdrive pedal set as a booster to color my "clean' tone. The Barber Gain Changer does an excellent job on my main board for this. On my travel board the Timmy does the same duty.
    Marc Morfei and thegeezer like this.
  6. beninma
    beninma Friend of Leo's
    Earth
    Finite (pedalboard) space and money.
  7. cyclopean
    innsmouth, MA
    so actual constraints and not some weird cop in your head must plug straight in purity thing?
    TelePunkJCM likes this.
  8. Toadtele
    Toadtele Tele-Afflicted
    Idaho just the tip
    I think we all should have one. Just my humble opinion
    Axegrinder77 likes this.
  9. Axegrinder77
    Axegrinder77 Tele-Afflicted Ad Free Member
    Springtown
    I find that a bit of compression just makes me sound a bit more "pro."
    It seems to let rhythm chord work cut through, because it is more dense and full - squashed in its tighter dynamic space
    Lead work you get more sustain obviously. And it smoothes things out a bit. It also induces you to lower the gain or level on dirt pedals.. So you can get a better tone sometimes without the perception of less gain.
    Sometimes you'll want you dynamics back, and that's when it's time to turn it off. It's nice to have the option though.
    Ime, compression is something you have to just use in order to understand what it does sonically.
  10. brookdalebill
    Austin, Tx
    You may need one, it’s OK with me, but I hate em’.
    I never need as squished/squashed tone.
    I utterly don’t get em’.
    A clean boost, yes, I understand that.
    You might consider a Durham Sex Drive.
    They boost, and offer a light optional compression.
    TelePunkJCM and thegeezer like this.
  11. JL_LI
    JL_LI Friend of Leo's
    Long Island, NY
    A compressor is a tool. I use one. Occasionally. Do you need one? A better question is do you need what a compressor does. Do you need to balance strings? Do you need add sustain? Do you need to thicken your tone a bit? Do you need to use the compressor as an effect as opposed to a modulation pedal to squish the tone? Answer yes to any of those questions and maybe it's time to go shopping, but don't go shopping until you are certain the solution to your problem can't be found in improving technique. Then ask yourself if a compressor is the right tool. Do you need a compressor or a clean boost. Remember, a compressor isn't magic. It's a tool. Make sure you get the right tool. You can hammer a nail with a hammer or the back side of a shovel. Only one of them works well. You can shovel snow with a snow shovel or a garden trowel. Again, the right tool does the job and the wrong one can be more frustrating than not having a tool at all.
  12. Bendyha
    Bendyha Friend of Leo's Silver Supporter
    Northern Germany
    I just recieved my new compressor last week:D, and it is certainly changing my ideas about what these things can do...
    As you can see, this one does a bit more than my old two knob MXR Dyna Comp. and I'm still playing around with the possibilities....
    Do I like it? -YES!
    Do I need it....well, I'm learning to.
    Paul in Colorado likes this.
  13. DOC DYA
    DOC DYA Tele-Meister
    Luçon _ France
    Sure, a compressor should help you... but may be you could, also, think about the sound of the whole band around you... There's an interaction between the "sound range" of the band when you play "dirty" or "clean"... My two cents!!!
    Hatfield92 likes this.
  14. ndcaster
    ndcaster Poster Extraordinaire
    Indiana
    I'm gassing for a Cali76
    so good for country snap
  15. Paul in Colorado
    R.I.P. 2019
    Address the basic issue before throwing "cures" at it. Figure out why the clean sound isn't coming through or is weaker. A compressor might help, but work on what you have first.
    Bendyha. What is that comp? I have a stereo rack compressor that has fewer knobs then that.
  16. Bendyha
    Northern Germany
    These things are fresh on the market, hand-made in small numbers (up to now) in Romania becosfx.com compiq-pro-stella-compressor-pedal-for-guitar-bass
    The first small batch sold out quickly, and I had to wait for about a month after ordering mine untill the second batch was made, but there should be built up stock available soon.
  17. cyclopean
    innsmouth, MA
    i'm pretty sure i don't need one because my signal is pretty squashed coming out of my pedal board and being fed into a an always on clean boost.
  18. artdecade
    artdecade Poster Extraordinaire
    Boggo Road
    Been playing a long time - never needed a compressor.
  19. drewcp
    drewcp Tele-Meister
    Saint Paul, MN
    No, you don't need one. They can be useful tools though.
  20. scottser
    scottser Friend of Leo's
    dublin
    Sounds like a job for a decent eq pedal more so than a compressor
