COMPLETED -- "Tidycatster", the $100 telecaster challenge
Discussion in '2009 TDPRI Tele Build Challenge' started by guitarbuilder, Feb 11, 2009.
Thread Status:
Not open for further replies.
  1. guitarbuilder
    One Lap Scratch Guard.... Hey Purina, if you happen to catch this thread... I bet the local shelter could use some cat food and litter. Those are recycled screws from a superstrat that got cannabalized for its parts.Go green...Recycle and Reuse as they say.
    Random thought# 3 or is it #4.
    I can see some knobs in that red handle that I just took off that yellow bucket before I hacked it up.
    Capital outlay so far. I haven't purchased anything yet. Just glue, leftovers wood, metal, and used screws. I know I have the used parts from junky guitars to do this without any cost, but I just can't see putting used electronics ( pots, switches, caps, etc )in this after all the work. Oops I did use 2 new sheet metal screws for the lap saddle. 10 cents?
    I'm thinking one single coil right above the kitties.
  2. guitarbuilder
    Here I am laying out some lines to line up the pickup cavity template in the pickguard. I've put some masking tape down to draw on and protect the plastic.
    Then the pattern goes on with some double sided carpet
    tape.
    Then it gets routed out with a pickup template
    http://i152.photobucket.com/albums/s162
    [IMG]http://i152.photobucket.com/albums/s162/mmgguitars/pickup4.jpg/mmgguitars/pickup3.jpg[/IMG]
    Finally a pickup fits in.
  3. Parma_TeleMon
    Parma_TeleMon Friend of Leo's
    Columbia, MD
    My grinnin' muscles are gittin' sore!
  4. guitarbuilder
    You know I have that other body....hmmm triplenecker??????
  5. lammy
    lammy TDPRI Member
    Brooklyn
    yesss!! Guit steel!! amazing!
  6. boozer
    boozer Tele-Meister
    Langley B.C. Canada
    this is awesome... period
  7. guitarbuilder
    Well I took the plunge today and cut off the bottom of the body and cleaned up the edge for gluing. I drilled a hole from the pickup cavity where it will join the control cavity. I added the glue and clamped it together.
  8. guitarbuilder
    I took the clamps off, scraped some glue off, drilled a couple of strap button holes, drilled some lap dot holes, and prototyped some knobs. These are toothpaste caps and red cutoff's from the tidy cat handle. The caps already have a knurl to them.
    I think I'll do some type of plastic top to them too.
    Still no purchases yet for this thing. 10 dollar ceramic magnet pickup- new. I have some used ones if I need to save the cash for something later. I think we're up to about 11 dollars here so far. Glue, 2 screws, one pup.
  9. robt57
    robt57 Telefied Ad Free Member
    Portland, OR
    I didn't realize the lap would be so close to the Tele control. Any chance the tidy stock is big enough for a one piece for both the tele and the lap ??
    I'll bet a nickel you already thought of that... ;)
  10. guitarbuilder
    Robert, I didn't want to put the lap any closer to the neck... I wanted some playing room. When you set the lap on your lap, I didn't want an uncomfortable feel by making the player stretch out any farther to play it. Time will tell whether the ergonomics are correct. Obviously this is a concept instrument like what they do at GM with their Vettes :). The production models may vary. I had one of the cats down in the metal shop make a quick plate from a foil container. Taipan better start worrying now. This one is a whisker off though....
  11. fisherbim
    fisherbim TDPRI Member
    Jeddah, Saudi Arabia
    never seen a lapsteel made before...heck, never seen a lapsteel attached to a guitar before and to a tele...now that's a lot of firsts...simply big wow!
  12. guitarbuilder
    Yeah, my first one too....LOL. I hope it's not a big waste of recyclables and time.
  13. Mike Simpson
    Gilbert, AZ (PHX)
    Are you gonna mount it at an angle on a stand like Junior Brown?
    Fisherbim, google Junior Brown and listen to him rip it up on the guit-steel.
  14. guitarbuilder
    We'll see if time permits accessories for it :).
  15. guitarbuilder
    Time for a little metal work. This is a hunk of 25+ year old aluminum tubing. I cut a couple of pieces for some fabrication.
    I gave one a little persuasion to flatten out.
  16. robt57
    Portland, OR
    I think I am going to rename my C-note caster project to 'Tidy Bowl Caster' or would it be Catster?
  17. guitarbuilder
    I sheared off a hunk and rounded the edges with a file. I countersunk the screw holes and tried a fit with the rest of the parts. I'll need to adjust a few things to make it all work together. I haven't decided what controls to use yet. I have quite a few schemes in my mind.
  18. fisherbim
    pickguards are really cool sir...
    he's amazing! thank you big mike...
  19. lammy
    lammy TDPRI Member
    Brooklyn
    I have been transcribing some junior brown on lap and on guitar, makes me wish for a guit steel!!!
  20. guitarbuilder
    I figured that I needed something to keep the lap strings from cutting into the wood. Here are some pop rivets with the mandrels removed sitting in the holes I drilled for the strings. I'll super glue them in after sanding and finishing.
Thread Status:
