COMPLETED, The Scattesquire
Status
Not open for further replies.
Thomme
Normal
I don't know how much a quality contribution this may be, but I'd like to suggest you do some different tuning on the shorter neck. It really depends on what you intend to play on it, but if you were to tune it like a 5th or 7th higher than a standard guitar, you could play some nice jangly chords. I doubt that's really the intention with the esquier pickup setup on the shortscale side, but, that's just my two cents on it. Yours builds are just godly, Scatter. I would give my left arm to be able to build guitars like that... of course then I wouldn't be able to play... so, that's a pretty bad catch 22.
Scatter Lee
follow the buzzards
well I made this today for the double neck, the screws that came with this switch had such big heads that no matter how you attached it the knob would jam into the screw heads and pretty much made it a two way switch, but it's a four way, so I had to buy some flat head screws and grind them down to oval heads and all is good
Scatter Lee
follow the buzzards
waiting on frets and tuners for this one but it's not for the challange anyway,
my good camera bit the dust so here are some bad still pics from the handycam
partscasteruk
Devon, UK
Really loving the competition so far! Mr Scatter Lee, yours is the thread I've been most captivated by but I'm just so in awe of all you guys...
Scatter Lee
follow the buzzards
OK folks I'm all done with this, no more fun time, gotta get back to workin,
I burned up a saber saw
broke the dremel
burned up a drill
my most used drill bit makes more smoke than sawdust
my hacksaw blade dont have many teeth left
router bits are a bit burnt
and the camera quit working
but its been fun for sure
here's my final pics
Scatter Lee
follow the buzzards
total weight = 6lbs 13oz
Neck.............................hand made, scrap wood
Truss Rod.....................hand made from metal rods----------------$3.75
Tuners, w/Screws...........................................ebay------------$19.95
Bone Nut Blank................................................ebay-------------$0.85
Body..............................hand made, scrap wood
Neck Mounting Plate, w/ Screws.........................ebay-------------$1.42
Strap Buttons w/ Screws..................................ebay-------------$3.14
Pickguard......................hand made from scrap fiberglass
Pickguard Screws, Stainless.................................Lowes----------$1.35
Bridge Pickup
w/ Mounting Screws & Rubber Tubes......................ebay----------$17.00
2 Used Pots
w/ Caps & Nuts & Washers..................................ebay------------$5.00
Used Switch, 3 Way w/ Screws.......................parts box-----------$5.00
Used Control Plate w/ Screws..........................parts box--------- $5.00
2 Knobs.............................................................ebay---------$10.50
Bridge.............................hand made from scrap metal
Bridge Screws..................................................Ace-------------$0.48
Bridge Saddles................hand made from scrap bolt
Bridge Intonation & Height Screws..........................Ace-----------$1.35
Bridge Springs.......................from old retractable pens------------$0.15
Output Jack....................parts box-------------------------------$1.50
Output Jack Ferrule.............................................ebay----------$0.60
Output Jack Ferrule Screws...................................Ace-----------$0.10
Frets...................................................................ebay---------$8.99
Strings.................................................................Store--------$3.49
TOTAL..................................................................................$89.62
Status
