COMPLETED - Patsanger's Pistachio Tele!
Discussion in '2014 TDPRI Tele Build Challenge' started by patsanger, Mar 1, 2014.
  1. patsanger
    patsanger Tele-Meister
    If you look you can see the graft line in the woods. Apparently the trees can be grafted a few times before they have to be completely replaced, and so they are typically seen grafted. When they are fully pulled up they can be salvaged and used for some wood - hence how you can see the graft here.
    I got it from - http://oregonwildwood.com/guitar-wood/solid-body-electric-guitar-woods/pistachio-top-sets.html
    I think I am going to put the graft at the neck side of the top.
  2. XxJoshxX
    XxJoshxX Tele-Holic
    FLORIDA
    You have an Ormsby on the way, right?
  3. axedaddy
    axedaddy Tele-Afflicted
    Winter Haven, FL
    Great wood choice. Mike Tobias said that the Pistachio he has been using on his high end basses is his favorite wood right now.
  4. patsanger
    Yup, and the builds get started soon...
  5. patsanger
    I've been slammed with a bunch of non-tele work stuff and so I have been stuck just making my templates and stuff. I got some new equipment from my wife (sander, drill press and band saw) since she thinks it's cool that I am finally doing this type of stuff. So I am learning those as well. I should be cutting and doing the majority of the work within a week.
  6. patsanger
    Wheee! Let's get this started!
    Ok - proof of woods was first pic earlier - check
    So I made my body template and sanded it down then traced it onto that nice piece of white limba
    Then I cut it out with my new bandsaw (my wife got me new tools as a surprise!)
    and sanded it closer to the line
    and I was playing with my router to get it to work right... started getting the template and bearing to touch before I had to quit for the night.
    Hopefully tomorrow I can plow ahead with it some more.
  7. Jfellows
    Jfellows Tele-Afflicted
    Tracy, California
    Glad to see you making progress on this Pat! Looking forward to it.
  8. patsanger
    Finished routing the exterior of the body and then found that I used waaaaaay to much double sided duct tape. 30 minutes later I finally got the template off. Dang!
    The white limba has a cool pattern and now I'm thinking about saving the pistachio and just making this a white limba tele... hmm
  9. barbrainy
    barbrainy RIP
    Northampton, UK
    Ooooh, that is a nice pattern! Kind of looks like water cascading down a windowpane....
  10. nosmo
    nosmo Friend of Leo's
    Lake Jackson, TX
    :eek: But...bu...but...then it won't be....Pistachio colored! :eek:
    It does look pretty nice though :D
  11. hemingway
    London, UK
    I vote pistachio! I vote pistachioooo!!
  12. patsanger
    Spent most of the day trying to get a thinline template to work and gave up. I'm going to chamber it, but keep the top solid (like Lucille).
    After I cleaned up I realized I needed to glue the top so I went and tried to edge/router trick.
    And that almost worked, so a little sanding got it to be about where it needed to be and I did the tape join idea.
    and then weighted it -
    a quick wipe of thinner before gluing just to look at it..
    whee!
  13. hemingway
    London, UK
    That is spectacular wood!
  14. Model T
    Model T Tele-Holic
    NY
    Sticking with the pistachio was a good idea. It's gonna look really nice.
  15. DrASATele
    North of Boston
    It took me a couple of passes and adjustments but I got my router to work as a joiner. It really takes patience. It works really well if you set it up correctly. There are a few fest tool videos that show you how to do it easily. Looking good, I really like the white limba.
  16. patsanger
    Thanks everyone. I tried a few times just shaving it here and there with a straight bar in place, but it just was always a little off, so I sanded the offending part cause I only had so much time. :)
  17. patsanger
    Today was busy...
    Hogged out the body - then I had to semi free route it (with only 1 oopsie, so that's ok) - and just as I thought , whew, that's that I realized that putting in cable channels now would be super helpful, so I guesstimated where the pickups would go using my templates and threw in some channels - so worse case I can hopefully just have to barely drill to hit them...
    Now it was time to check out the top... and the slight warping it was doing did not get corrected by the weights etc so I had some unevenness in the center... a good join, but not even... so took my 2 foot level, taped on some 60 grit and started sanding... and sanding ... and sanding...
    finally flat... and traced the template..
    Yay!
    Judicious application of glue which was then rollered everywhere, on both surfaces, and then glued up and clamped...
    and then, just as I thought I was done I realized if I didn't at least cut the neck out, I would have less incentive to mess with it tomorrow, so I cut it out.
    Good - got some good steps done and was really happy with the way most of it went, it's not perfect, but I'm shooting for better than last year and so far I feel I am there.
    Bad - sanding - waaay too much sanding and leveling. The top tape method didn't work for me due to the warpage and next time I will prob make a jig and handle it that way. I really need to make that thicknesser sled or buy a planer.
  18. hemingway
    London, UK
    I'm so glad you went with the pistachio. It's going to look so special.
  19. patsanger
    All right - just a quick update for today -
    unclamped and looked, pretty good, some small gaps but I can fix that...
    routed to body
    2 small things to fix - this is from cutting the body shape out, my error with the bandsaw, I can fix it
    this is the only blowout I had and I was lucky... I can fix it..
    And out in the light with a quick thinner wipe...
  20. lbridenstine
    lbridenstine Friend of Leo's
    Kalamazoo, MI
    That looks really nice!
