COMPLETED -- $100 Telecaster Challenge-The $124.01 CADocaster
Status
Not open for further replies.
martyb1
Alberta,Canada
That's right... and if I was a judge I would give higher marks for shiny, as the finish on the body suits it better. IMHO. ;)
The finish as pretty shiny but not like a regular build.Because I only used sealer and no grain filler the finish has sunk into the grain in a few spots,but on the flip side,the aged hardware is all Fender stuff that I scored on ebay,which is actually more money.I can still get under budget using it but using the shiny stuff gives me more room.Only thing is that the neckplate and tuners are not aged so I think I will go with the cheaper shiny stuff.
Better get back to it:eek:
martyb1
Alberta,Canada
Time to double check the line up.Got the neck clamped in this time.looks ok
Use the screws to mark the neck
Over to the drill press,drill the screw holes
Stick on the plate and screw it down.
Hmmm,even reasonably straight!
martyb1
Alberta,Canada
Before I can go any farther I will need to get the nut in the neck
Marked the outside slots
Used my nut spacing ruler made from scrap binding to mark the other holes
Now into the vise and make some slots
martyb1
Alberta,Canada
Start them with a 3 corner file
Then use the nut files to make the slots,not too deep now
Slip it in the neck.
Now I need to find 3 strings
martyb1
Alberta,Canada
Since I have no copper shielding here I will give the cavities a coat of shielding paint
NOw I need to add some wire to the pickup lead
And wire up the control plate
martyb1
Alberta,Canada
I bet I can find some wire in here,an old dead CB radio that I cleaned out of my moms shed
Yep,there is wire in there
Since there is nothing traditional about this guitar,why use traditional colors
Solder up the plate
martyb1
Alberta,Canada
Think I will use a pink wire for the bridge ground,it's the new beige you know
Set on the bridge and feed the wires
Line it up and install one screw
Make sure we are still lined up and put in the other 3
martyb1
Alberta,Canada
Now I need some foam for under that P90
Got some garbage left over from tinning the shed
Slide in the P90 and screw it down.
Now I see my route is off a little.That was because of the smaller heel on the neck.I didnt compensate for that when I did the route.The strings still catch the pole pieces though.Might even be the pickup.What can you expect for $4
NOw wire up the pickups and the output jack
WOW,getting short on time.Got to head to my gig soon.
Drilled and installed the strap buttons
Added a string tree
Plugged it in and we have noise!!!!!
All positions work,and very little string buzz.
I will let it sit over night and set it up in the morning.WOW,this was cutting it tooooooooooooo close
Colt W. Knight
Garland, Maine
Well builders, I think Marty pretty much has this one wrapped up. We can't compete with that!
That just means we get to keep ours. HAHAHHAAHAHA!
Colt W. Knight
Garland, Maine
Well, I just effed up the paint on mine, so I know for certain I don't have a chance against these beautiful guitars.
Then again, I never set out to make mine pretty, I kinda wanted it to look like a home made 100$ guitar.
martino
LA CA US
Colt Get a pair of work lights and some acetone you can save it . . .
Yes you can!!
TDPRI
Retired
All this thread needs is a final $ accounting post and it looks done. Good Work!
martyb1
Alberta,Canada
Well just got home from my gig.I better do the accounting post now.I may sleep past the deadline :eek:
Bridge-$18-Ebay
Tuners-$9.99-Ebay
Neck-$20 Eden
Buttons-$1.75
Binding-$4.00
Pots-$5.00-Used
Switch-$6.50
Output Jack-$2 Used
Neck Plate-0.99-Ebay
Control Plate-$3.24-Ebay
Switch tip-$1.00
Ferrules-$4.00
Str Tree-$1.25
Cap-$1.00
Button Felts-$0.50
Strings-2.00-Used(well 3 of them)
Pickups-Bridge$0.99
Neck $4-Ebay
Knobs-$3.25-Ebay
________________________________
Total is $89.46 I think,pretty tired
The left over can go for Finishing supplies,shielding paint,etc
Everything I needed screws for they were included
Hope I didn't miss anything
Status
New Posts
