COMPLETED -- $100 Telecaster Challenge-The $124.01 CADocaster
Discussion in '2009 TDPRI Tele Build Challenge' started by martyb1, Feb 13, 2009.
Thread Status:
Not open for further replies.
  1. shoretyus
    shoretyus Tele-Holic
    canada
    Just dye the leather a more subtle colour. I'll give $124 Canadian Tire money if you don't win.
  2. Douglas Ingram
    Douglas Ingram Tele-Meister
    Lorette, Manitoba, Canada
    A bigger route for a flush fit, dye the leather black, and epoxy it in place. Would look great. Too late?
  3. martyb1
    martyb1 Tele-Afflicted
    Alberta,Canada
    Yep,there has been a major morph in the direction in which this build is progressing;)
    Pics to follow:twisted:
  4. martyb1
    Alberta,Canada
    Well I think my last marble has fallen out:eek:
    Pretty much figure since I have this big route with nothing to go in it,why not make it BIGGER!!!!!
    I have a multi profile edging bit,have never used it,so............
    I set it up in the router,picked a spot on it that would take out the square route.However doing that it added a couple more routes
    We have one majorly weird carved top now:twisted:
    Didn't take into consideration the output jack hole though
    So I made a plug from the cutoff from the body,glued it up and drove it in and run it by the router again
  5. martyb1
    Alberta,Canada
    With all the router work I managed to scratch up the burst pretty bad,so it had to come off
    Since this is going to be totally weird,lets make it weirder and add some binding
    The route is so low that part of the binding will go all around the body
    Hmmm,what color.
    Well lets make it stand out!!!:eek:
  6. martyb1
    Alberta,Canada
    Pulled the tape and trimmed it up a bit
  7. martyb1
    Alberta,Canada
    Give it a shot of sealer to help smooth out the new routes
    Probably should have give it more but times a tickin and I am back to work for 10 days.
    Now tape off the binding to put the burst back on
    Hmmmm,what it we taped off the next ledge and made some natural binding too!!!
    Now the amber goes back on
    That output jack was bothering me.I knew I had an old jack I took out of a Japanese tele a while ago.I'm sure I saved it.While the amber was drying I hunted it down
    Good thing I didn't make my plug full depth
  8. martyb1
    Alberta,Canada
    Now for the black,again:rolleyes:
    Mixed up way too much so I will save it for late.Good old baby food jars
    Then after the black was dry,on goes the middle ring
  9. martyb1
    Alberta,Canada
    Now touch up the black
    There back to where we were,almost:rolleyes:
    Now let that dry a bit and pull the tape
    I had a little seepage under the tape.Not too bad though.I will call it a night and let it cure.When I get home tomorrow I will scrape the binding and see if I am going to keep the natural binding
  10. robt57
    robt57 Telefied Ad Free Member
    Portland, OR
    You are a bursting Mofo! Nice creative direction there!
  11. chromaken
    chromaken Banned
    Northen California
    I really like the sunburst and how it looked before you pulled off the tape. Solid black around that routed edge was really really nice.
  12. robt57
    Portland, OR
    But it will look sweet when that routed bead matches the center of the burst.
  13. BAW4742
    BAW4742 Tele-Afflicted
    Maryland's Eastern Shore
    Great save Marty. The leather binding looked nice but this is much better. The double bound look is sweet!
  14. Douglas Ingram
    Pick up, march on, don't look back, don't cry over it. That is the way of the artist. Good going.
  15. martyb1
    Alberta,Canada
    Just another wonderful March day in Alberta
    -14*c with wind gusting between 60-100kph
    I normally check 40-50 gas wells each day.Today I got stuck going to the first one!!
    Here is a pic I took with my phone from the door of our office.The trees you see are about 40 yds away
  16. Nick JD
    Queensland, Australia
    You're lucky, Marty! We're either under ten feet of water or catching fire. Now I look at the weather maps and what do I see? A tropical cyclone, aka a Hurricane currently at category 2 rising to 3.... :eek:
    Have a look at the NE tip of Australia, at the top of the Great Barrier Reef.
  17. martyb1
    Alberta,Canada
    Not sure if you would call it lucky!!!
    I have to admit,I can take the cold better than I can the heat.You know what they say,you can keep putting on cloths but you can only take so many off :eek:
    One good thing was we got to come home early.13 miles took me over an hour to get home.
    Figured I better clean up the binding.I found that one of those finger nail emery boards sanded square worked great for cleaning up the faux binding
    As for the pearloid,just the regular utility knife blade and the home made scraper
  18. martyb1
    Alberta,Canada
    You know I never even thought of that.If I would have I would have taped it off after I shot the amber.Good idea though so...........
    Out with the tape
    Pretty sure it would have worked without taping it off but wanted to make sure.Then a shot of the special mix
    Give it a few minutes and then pull the tape
    After it is dry I will wipe it down and give it all a shot of clear
    Thanks for the idea robt57!!!!!
  19. boozer
    boozer Tele-Meister
    Langley B.C. Canada
    wow!!!
    looks awesome.
    great save.
  20. steve gibson
    steve gibson Tele-Holic
    fort dodge, iowa
    It is going to be impossible to pick a winner in this contest given all the talent, artistic ability and innovation. I am glad I am not judging. Inspiring work!
Thread Status:
